Utsource fake??
I'm sure they do, whether they realize it or not.
If the US military can be duped into buying fake parts, it's almost a guarantee that a HK parts broker also buys/sells fake parts.
That said, I've always had excellent service from utsource and the parts have always worked, fakes or not.
Reactions: 1 user
I bought Toshiba 2SK2013/2SJ313 from UT Source, too. And they were not fakes (measured and tested, in compliance with datasheet).
People often declare parts to be fakes based only on visual examination, without proper testing. Many parts have been produced in different housings, depending on year of production and that causes confusion among users who weren't able or willing to execute serious testing or serious research (there are different datasheets for parts produced in different years).
I’ve bought many hundreds of transistors, FETS and capacitors from HK based ebay stores and not a single fake in site.
I’ve had wrong parts suppled, wrong number of parts supplied and wrong batch numbers supplied but no fakes.
This whole fake transistor business is blown completely out of proportion.
By the way… I don’t consider an On Semi MPSA 42 for example a fake as long as you know you are getting an On Semi device and not a Motorola!
Disabled Account
Joined 2006
Utsource do supply fakes or should I rather say second source. I had this with toshiba drivers. The parts supplied looked exactly like the original toshiba down to the markings. The only suspicion was the too shiny legs of the components. Well they did turn out to be the parts in question but they were not from toshiba, they were manufactured in Hong kong and said to be second source, the problem being that very little of them in a batch of 500 came close to datasheet specs. They do work but will not perform as well as suggested by datasheet info. When I finally located real toshiba, less than 1 percent of them were slightly off and all better than the supposed components from Hong kong. KEC also manufacture the pair, nowhere close to datasheet specs, much slower.
Please note that toshiba does not supply licencing for second source manufacturing for parts still in current production.
Disabled Account
Joined 2006
Thats probably because you dont know how to distinguish or you dont measure to conform that they perform according to spec. The parts do work, thats not the problem.
Perhaps you dont know but ONsemi bought the Motorola semiconductor manufacturing company part of Motorola back in 1999 so you getting the parts exactly from the same factory and made by the same machines and probably the same staff, only the company name has changed.
Disabled Account
Joined 2002
Try Ebay, find Toshiba 2SA1302 for instance. Report back if the amp you soldered them in still functions... I agree that the fear for fake parts is out of proportion but I have experienced fake TDA1541A and fake Wima caps so things are not made up. BTW the fake Wima caps were in a branded preamp.
Disabled Account
Joined 2006
Some attention has to be given to this but on the other side fakers have upped their game and in some cases near impossible to distinguish till youve measure.
I had parts bought from a authorized EOL distibutor that turned out to be fake, quite to the shock of that distributor. It was hard for them to argue with the company who originally made the part and said there was no record of the batch. THey swore they were original, but my money was returned. Go figure. The fake parts business is in full swing. Don't believe me, go find FQA19n25C. You will find 100's of thousands, none that are original.
Disabled Account
Joined 2006
Look at headphone forum, even Richard Marsh has been done in. ;)
He hasnt even realised it yet, I dont think, although Ive pointed it out. So if ever I see this happening in a commercial product I wont be surprised.
Homemodder, I don't know if fake or counterfeit is the correct term. I have bought several counterfeit 2SK1058/2SJ162 in the form of being cheap Hexfets that has been reprinted. My favorite picture is this one. I cannot imagine that it could be profitable to do this, but obviously it is.
You hit the point on the head. Is it an On-Semi, or was it a reject out the back door of any old transistor that someone stamped On-Semi? On Semi makes some pretty poor transistors, but they will be within minimum spec. Night shift rejects won't.
The problem is VERY serious. People have been killed. Billions of dollars have been lost in aerospace and military rework. I need to say that again. People have lost their life due to counterfeit parts failure. Several military incidents and at least one airline.
The blame is to be applied across the entire cycle. Foundries need to dispose of defects, factories need to not be doing off-book runs at night, wholesalers need to know who they are dealing with, as to end suppliers. We made this worse by having laws to support small business, forcing purchase through middlemen with no ability to track the parts provenance. Who knows how many were bought from "some guy" with a box of parts? Pulled out of old boards and repainted IC's? Second shift "private" packaging runs? Counterfeit parts is big business. Foundries sell raw chips without monitoring if the packaging is what the chip is. Things like a cheap DAC or Op-Amp being packaged and sold as an expensive one WITH THE FOUNDRIES NAME on it. How do you know if that $29 latest super op-amp is not really a 741?
This will take serious international police action to clean up. There is one country where most of the problem lies, by default as that is where the foundries and packaging plants are. We need them to do the most. They are trying. They will succeed. Capitalism is new to them and it takes time to learn you really do need rules in a knife fight. Look at Western capitalism history in the late 1800's and early 1900's. UGLY. They need help from the suppliers, be they in HK, UK, or Kansas. They need help from the end users to scream as loud as we can when we fall victim. We need criminal prosecutions. It is hurting the global economy as there is less trust in business than there could be.
Good business is good business. If you make an honest dollar today, you stand a better chance to make another one tomorrow. This message has not had time to sink in.
Disabled Account
Joined 2006
That pic has become mystic in electronics circles.
Tvr, good and very truthfull argument, a certain country would probably come to a economic standstill if the fake business were to vanish as it doesnt only apply to electronics but accross many and I dare say all industries from clothing to beauty products to you name it. Their goverment is well aware of this and the reason they dont do anything about it.
I didn't know on semi bought motorola but that just makes my statement more correct.
I test every transistor I use for vbe and hfe so you are assuming incorrectly there. I've had bin ends / seconds supplied but then again I paid nothing for them so you get what you pay for.
A fake is a device labeled as something it's not.
Disabled Account
Joined 2006
Measuring vbe and hfe doesnt begin to cut it at all, Testing for things like Vce, SOA, FT, capacitances is needed to sort fake from real parts. I could pass you a rf transistor for a mpsa on the basis of just hfe and vbe (both having lowish hfe figures but Rf transistors in near all cases low vce), youd only find out when you applied high voltage to it as an example.
You perform SOA and vce tests on all the transistors you buy to decide if they are fakes or not? Wow.
Disabled Account
Joined 2006
Homemodder, I believe that (not so) thorough bred German motorcars are being manufactured in this country but even their own people resist to buy locally produced vehicles and go to length to obtain the imported version. And that is not even counterfeiting.
I saw them on sale in Madrid some weeks back, you can only tell when you take a closer look, accross a hall youll be fooled. Istill dont understand how certain countries allow this and even legal routes have failed to to correct this. Me thinks the the not so thorough bred doesnt even come close to the original datasheet spec. :D:D
Shuanghuan SCEO - Wikipedia, the free encyclopedia
