MPP
Joined 2006
The TX finally found their way up here.... Swiss Post is very strict and I was using my job´s mail instead of home mail... the package came from France and was rejected by the mail post office... I believe they use the mail information to keep track of people here.
Now building a wall suport for the TT because my "new" house is very old and has floating floor boards.... Hope to be able to listen to the Paradise during next week.
PS: Thank you both for the IRC RN 55 info:)
Does anybody know a german distributor
for those IRC RN 55 thingies ?
There is Mouser to start and a few more as folows.
Igot those from gogleup IRC site so maybe same won't work
ELTEK Semiconductors ltd - GERMANY
IRC Distributor for Silicon Dice (Only)
Nelson Road Industrial Estate
Dartmouth , Devon TQ6 9LA
Phone: (+44)(0)1803-834455
Fax: (+44)(0)1803-833011
URL: Eltek Semiconductors Ltd
Mouser Electronics- GERMANY
Elsenheimerstr. 11
Phone: +49 (0) 8952 04621 10
Fax: +49 (0) 8952 04621 20
Email: munich@mouser.com
URL: de.mouser.com/
Rutronik Elektronische
Industriestrasse 2
Phone: 49-7231-801-431
Fax: 49-7231-801-416
URL: RUTRONIK: Homepage
TTI, Inc. - Dortmund
Phone: +49 (0) 2301 9450 - 0
Fax: +49 (0) 2301 9450 - 11
URL: TTI Inc. | Electronic Component Distributor
TTI, Inc. - Hanover
Phone: +49 (0) 511 78 05 90
Fax: +49 (0) 511 74 24 90
TTI, Inc. - Munich
Phone: +49 (0) 8142 66 80 -110
Fax: +49 (0) 8142 66 80 -199
TTI, Inc. - Stuttgart
Phone: +49 (0) 7231 14788 - 0
Fax: +49 (0) 7231 14788 - 99
Joined 2005
Tanks hesener
I was pretty sure of that, as I could not find MKP on that footprint.
I have already quite a few MKS 2.2 uf from buerklin any detrimental reason not to use those?
these should do fine. please remember that the caps in the shunt regs and the servo should have 1uf as per schematic, else you are changing the time constants. the other caps are optional, 2.2uf should be fine. the footprint is 5mm but you can drill further holes to make them fit (watch that ground plane for accidental short circuit, though). DC voltage rating should be 30V min.
you may have notednthat the holes for the power diodes in the shunt reg are a little tight, thats already fixed....
let us know how you progress, any issue with the betabuild please drop me a line so I can fix the PCB......
have fun!
Tanks hesener I will get the 1 uf I have made same progress with part bom text in red need if you could looking at
I have not included the semiconductors parts
Resistors are IRC type + reccomended parts from your notes
PS
Cut and paste part numbers to mouser will take you directley to those
  • Paradise parts bom.doc
have fun!
Oh yeh
Got pre-reg ond same FiFi raw suply cooking
for preamplifier from bolshy droog on other tread.
Those dudas give prety clean 35V at 140 mA so as I got one set already may as well make second set for Phono stage.
Sorry if taking long was hoping for pre-amp to be finished 2 weeks ago
Raw series Shunt reg
Separate Trafo box with emc filter and ...pre-regulator
Joined 2005
PS
looks good to me. for the 120/3w i used 2w, worked just as well
