How come this keeps popping out ?
Is my settings wrong somewhere or what ?
Siginal is low, barely above the noise floor.
basically all that you see is except for the little blip at the 0 time mark is the residual noise floor. Really it looks like you could not be connected and just the crosstalk is being picked up. I would test the output of the device by hooking it up to an amp or something. It could also be that the input gain is OFF at the lowest setting. Ideally you would measure with the output at or near full un-distorted volume and the input gain would be low.
Is this it ?
Have you turned the "Direct Monitor" switch off?
It was swithed off all the time.
Looking at the graph you may have a bit too much input gain as you show an input value above 1, IIRC 1 is full scale, so that would mean you are in digital clipping. I would lower the input gain just slightly.
I am under 1 now.
I must say that this is obviously software problem. Not with HOLM but with mine computer. Pin 1 is off and i disconected from internet because i noticed that when i open new page in the browser, a hissing sound starts. So i will disconect now and remeasure midbas to see impulse response and did we fix it.
Thanks again guys. See you in few minutes
I'm back. Impulse is still bad. I dunno how to fix that.
Can something be done with it other then buying a new sound card ?
Oh man the response is BAD on both ends though. But it looks like you have a signal now.
That's not good. It's possessed
adjust your output to -6dB and run it again. Or try the pad switch, if you have one.
I put everything on notebook and it works now
@NEO Dan...
Thanks guys
cool I was going to suggest turning the notebook sound back on, re-installing the drivers, setting it to be the default device for both playback and recording, and rebooting.
The reason for doing this is that some of the programs that may be running on your computer fiddle with the settings of your sound card, loading eq profiles or turning on effects etc. If you don't have your good card as the default then they don't mess with it, you just choose it in holm
Tony.
Tony.
Geez... I feel like walking dead I'm fiddling with it for about 8 hours today and yesterday.
There goes my short wacation
Here is loop measurement on notebook:
If i may say ... much much better. Thanks again guys. I'm one happy camper
- Design & Build
- Software Tools
- HOLMImpulse: Measurements in practice
