music particles will bump into non conducting transistors and break... jesus, this is elementary audiophilia.Yeah - what would happen if one switches on while the other switches off? The mind boggles...
but that's solved with Audionote caps and some $1000 worth of quantum purifiers.
you didn't do your homework, Julf
I never did - story of my life. Was hoping to be able to mount some flux capacitors on an old DeLorean and go back and fix it up, but got too much temporal distortion...
Great looking power supply, but I would hate to see a compact, efficient amp such as nCore saddled with a huge, bulky, inefficient unregulated PS...
The SMPS600 is switch mode, but unregulated
Datasheet:
Note 3: Output voltage is proportional to the mains line voltage (Min@180Vac, Typical@230Vac,
Max@264Vac).
that's why NFB, and PSRR, for that matter, are good things.The SMPS600 is switch mode, but unregulated
Datasheet:
Max@264Vac).
AFAIK, the only Hypex SMPS that actually is regulated, is the SMPS180. All the others are not.
SMPS180 is unregulated as well (only regulated AUX supplies).
There is more into regulated power supplies than low ripple.
A good regulated supply will prevent the amplifier from compression at power transients because of power supply voltage sag.
Our friend AP2 has some regulated SMPS's on offer (DP500 for example) which are regulated; he is quite a bit into this subject in connection with class A/B and class D amps (look at the Wire Amp thread....).
His supplies are a bit cheaper too
I kinda got bored, it's too long and most posts don't interest me. what was the conclusion?(look at the Wire Amp thread....)
Well, I'll help you out a bit.
The phenomenon of compression at power transients is a well known one with let's say middle of the road unregulated power supplies (not important being linear or SMPS).
OPC, the Wire Amp's OT, compared unregulated vs regulated (SMPS) and found the regulated supply to behave and sound better, especially in the bass department.
Unlike class A amplifiers, where supply current is constant, the behaviour of class A/B and class D amplifiers with respect to current demand is power dependent. Power supplies for this class of amps therefore are very important in what they are capable of.
Datasheet:
Max@264Vac).
I disagree. The output voltage is proportional to mains line voltage, but not influenced by output current (as it would with an unregulated linear supply). I am sure you noticed that only the aux voltage is described as "unregulated".
This may also be interesting to others, please can you explain why it is dependent on the AC main and not by the load?
Julf, what do you mean by "inefficient" linear supplies?
Do you mean according to size/weight ?
or power consumption at idle or different loads?
It seems to be something that is usually claimed around here, but I would like to know the origin of this claim.
SMPS´s usually appear to waste more power and dissipates more heat than comparable unregulated linear power supplies.
You can typically increase efficiency by going for a linear PS over a SMPS on a class D amp...
My ICEpower based AR ear two for example is spec´ed to be around 93% total efficiency (both amp modules and linear supply) whereas its SMPS variant only reaches some 86% as i remember.
This will probably depend on the used SMPS. Apparently the Hypex SMPS400 is spec´ed with much lower idle losses than the SMPS600.
I think it is something like 2W for the prior vs 5W for the later
I dunno the reason for why the SMPS600 should waste more energy, but it does make me curious...
-Are they spec´ed on similar terms?
cheers,
Since a regulated PS has rail voltage held constant by an active circuit, it is basically an amp driving an amp. It really sucks power, but should improve amp performance of an AB amp a fair amount. But with the extreme (85dB) PSRR of ncore it seems a waste, I expect gaining less than 1dB in any performance measurement. For the Hypex SMPS they warn against larger filter capacitance than what is provided: I expect it's because an instability could arise, from the greater inductance of more caps, or maybe the problem is a current limit, I dunno. It makes me wonder whether using a big ncore to supply another ncore is feasible, or a recipe for a loud bang.
It is my understanding (I might be wrong, hopefully the Hypex guys will correct me) that the SMPS600 works on a constant ratio of input to output voltage, but uses switching pulse ratio to regulate the power supplied to the load depending on current draw. Thus it is a regulated supply.
Size and weight are one obvious inefficiency.
Power consumption is a slightly complicated matter. A totally non-regulated supply (basically transformer, rectifier bridge(s) and capacitors) is not inefficient, but it is also totally unregulated, reacting to fluctuations in load by a voltage drop (and increase in ripple).
A linear regulated power supply is highly inefficient in terms of electrical and thermal inefficiency, as it has to dissipate a lot of the power in the regulating element.
I asked about this a few hundred pages ago. Bruno replied that the SMPS180 is regulated. The fact that you can adjust the output voltage, and that outout voltage does not change all too much with load indicates that it is regulated.....
My question:
http://www.diyaudio.com/forums/vendors-bazaar/190434-hypex-ncore-97.html#post2830278
Bruno's answer:
http://www.diyaudio.com/forums/vendors-bazaar/190434-hypex-ncore-98.html#post2830291
My question:
Bruno's answer:
What is a regulated power supply?
IMO constant output voltage with varying input voltage, right?
Then take a close look at the SMPS180 datasheet.
You will see specified that the unregulated aux output voltage is derived directly from Vcc and Vee (note 5), so it is apparent (at least to me) that the SMPS180 is an unregulated supply.
With respect to what we regard being regulated supplies, I state that all Hypex SMPS's are unregulated.
Bruno's remark that power supply current is "well regulated with respect to load" has nothing to do with this, and actually misleading as a reply to the question about regulation.
Any high quality unregulated supply will be able to supply the necessary current under differing loads (at the cost of more or less voltage sag), but when speaking of regulated power supplies we mean voltage, not current.
- Class D
- Hypex Ncore
