900W H-class PA Amp with Limiter
@crazymechanic s ground and main ground should be connected to main psu ground
@Djnits pls post photo something is wrong on your step drive high side negative rails is keep triggering
@ryanda 1n4148 is not good replacement of BAV21 use mur120
sir irvynejay here the pic of my h900
ok good to know that ,,have fun Bro
thanks irvynejay, and i want share this problem, to help some diyers to be careful of there project and double check, my circuit its look good or no short, but when i check it by tester totally short circuit, please see my attach pic. thanks w/ the help of sir irvynejay and sir apex,
thank's Irvy,..my h 900,.. transistor mje 340 and mje 350 is hot.,.my rail voltage is..80 40 0 40 80 VAC,.whats wrong for this?
