Studio Reference Amplifier
I mean 2 caps on the side(right & left) of my 3D preview. This caps are regards to C5, C6, C12, & C13 on apex schematic.
I saw Alex MM pcb adds 3 more 470uF caps onboard but don't know what it is for?
Anyway I will not do like that,
I will just add 2 100nF caps near the IC1 @+/- 15V to PGND
& one between PGND - SGND.
Still don't know what it is for :D
but I feel I need to do that.
These are my new pcbs, some parts are available on my drawer.. I will try to install them soon. I hope I have spare time.
The purpose of using the 3 pairs of caps for me is particularly I just wanna use some parts that I have them for some time ago. ha ha ha (joking )...Now I want them work for me...
Considering to Mr. Alex MM's pcb, I am sure he did it on purpose, putting some caps on board... I have a lack of skill referring to that science. But looking at my experience building the 1st SR200 that sound very good (IMHO)...I think I will do the same for the 2nd SR200, use the same topology as the 1st one.
Arif.
Nice PCBs, and dual TO220 diodes instead bridge rectifier...
Thank you so much Mr. Apex...
Could you please advice me the purpose of putting some 470 uf caps on boards. I just follow Mr. Alex MM's pcb design, referring to my experience building the 1st SR200 that sound very good (IMHO)...I feel there is an advantage doing that...
Many thanks.
Best Regards,
Thanks for your guidance
@Arif Budiyanto & DAMANHURI
congrats bro, I wish your SR200 will be finished soon.
Don't forget to try with & without additional 470uF on board & let us know the diference.
Mas DAMANHURI if you don't mind please share your/our new design & we wiil check here :)
Best Regards
I will soon complete the SR200 and I'm making custom components of the 3D version of the pretty sight, I'll change the components of you that you have sent with a custom component that I created without changing position. I hope this week will be completed soon and I'll let you Jhon. for the addition of 470 I will try, and I would also make the original version of APEX. you are my good friends who always share their knowledge.
I use a 50 VDC voltage. whether it is appropriate to the value of this resistance? where should I put this position to try detainees?
Maybe you can put safety resistor instead of the fuse, I put safety resistor parallel with the fuse (I install the resistor under the pcb). It is easier for me whenever I want to change my amp's bias setting, just need to uninstall the fuse, set bias as I wanted, and install the fuse back on board. CMIIW...
It is better to follow Mr. Apexaudio's advice, use 150R/10W safety resistor
Best Regards
Best Regards
OK Thanks Mas Arif. I try
