Hi.
Quick question. I noticed on the GB spreadsheet, it states the GB ends June 17th.
Is that correct ? Does that mean I haven't missed out ?
If you check the spreadsheet, it's not for SSHV2 but rather DCB1 and BIB. But drop a message to Tea-bag, he had some extra kits i believe.
Okay, all that are paid up should be shipped. Should have gotten a notification for it. If you did not - PM me and I will look it up from shipping website.
Non-US citizens, this is only traceable/trackable until it leaves US boarders.
I have extra boards and some kits available.
Are kits still available?
Does anybody know where to find any heatsink in the same style as these - https://www.aavid.com/product-group/maxclip/one-piece
I want to be able to mount them through the bottom of the case. 5°C/W will do for me, since i will only dissapate approx 4W with the IRF.
heat sink details
That's the link (I hope it will work):
OS515-50-B - AAVID THERMALLOY - HEAT SINK MAX CLIP - STANDARD | Farnell România
AAVID THERMALLOY - OS515-50-B - HEAT SINK MAX CLIP - STANDARD 50MM,
4.89°C/W
more details (pdf file) about the heat sink:
European Extrusion Profiles
4.89°C/W
I suppose I blew up one of the dn2450's?
Most possible. You could have blown even more semis though.
Thanks Salas. I'll check.Most possible. You could have blown even more semis though.
Ion, I do have some kits and PCB's left. Only 5 PCB's - but plenty of minikits.
Here is a good link to measuring IDSS. try to find a JFET closest to 4ma (range is typically 3mv to 5.5mv). If you dont find one, then at least write down measurements in case there is an issue later. I throw in 3 so one has a better luck at finding an ideal one, or replacing a blown one if it comes down to it
Transistor matching
Transistor matching
- Group Buys
- GB for Salas SSHV2 regulator
