Switchable Hi-Z input impedance, how ?
Ex-Moderator R.I.P.
Joined 2005
no :scratch1:
well, maybe the higher gain of ecc83 would be to have
my cheapskate effects are a bit noisy, and thickens the lower mids at higher level :eek:
and that is exactly what Im trying to avoid
so it seems Im still far from 'my sound' :mad:
I have ordered the new Palmer Deepressor pedal
but on backorder
Ex-Moderator R.I.P.
Joined 2005
ok, I got the Aikido mono solo boards
it will be my instrument input
and I expect my two channel Burning BA-3 (NelsonPass) will look like this
this will be my output gain/buffer
now I need some power supply parts
Ex-Moderator R.I.P.
Joined 2005
going to order trafo
planned voltages
0-195-215-235 (100mA)
maybe 100mA is a bit high for a preamp, I dont know ?
6.6-3.3-CT-3.3-6.6 (1.5A)
0-18 / 0-18 (1.5A)
and maybe I would like exstra voltages for effects, 0-9-12-15V
maybe getting a bit complicated in one trafo :scratch1:
Ex-Moderator R.I.P.
Joined 2005
BA-3, a full ground plane seems to make sense here
and where a hot connection is needed, I will just route away with engraving bit
a hybrid combination of hard wire and hole mount
would be really nice to have a small tool to route around the holes
Ex-Moderator R.I.P.
Joined 2005
Do you have any bass sound you are shooting for?
clean ;)
and natural, whatever that means
the only distortion I will accept is what makes it sound in the direction of acoustic bass :D
actually, right now, the only pre I have between my passive bass and power amp is a simple Bass EQ pedal switch thing
works ok
it even works in bypass mode :confused:
but it tells me that my future preamp build may be all I will ever need
that feels good, somehow
but if this speaker goes active, I will still have some means of controlling the sound :)
