Ok, thank you so much for your advice...If I supply this amp up to lets say +/-70V, will it give significant sound improvement? Now I feed this amp with +/- 59,5 volt, and I like the sound very much.Maximum supply for SR200 is +/-75V
Best regards,
Arif
Congrats, nice build my friend!SR200 from Indonesian forum
Best regards,
Arif
Suply this amp up to +/-70V will only increase power,
Ok many thanks Mr. Apex
So I will stay around 60Vdc.
Best Regards,
Arif
Thermal Coupled
Hi...
This my PCB design of SR200,
Are all these small TR need to thermally coupled?
I arranged them like that so it easy if it is need to thermally coupled
It is still need to be check again & if it its a bad design I will redesign again...
Hi...
Dear Apex,
I have 2 pcs of 4,7 uf Jantzen MKP, is it possible to use them instead of 10uf (C1), considering that now I use very low budget 10uf MKP. What is the result? Or should I have to find another 10uf MKP. It's hard to find good 10uf MKP in local suppliers.
I also have 2 pcs 2,2 Bennic's and 2 pcs Solen MKP and I plan to use them instead of 1uf (C4) for the same reason above.
Thank you so much.
Best Regards,
Arif B
Thank you so much.
Best Regards,
Arif B
Dear Apex,
Thank you so much.
Best Regards,
Arif B
It's possible to use 4,7uF instead 10uF in audio path, but no need to change 1uF in DC servo circuit.
Dear Apex,
Thank you so much for your fast response..
Are there any sound changes referring to this change by using 4,7 uf instead of 10uf? Because it means that the new one is less than 50% comparing to the previous value.
Many thanks.
Best regards,
Arif
Sound changes is unaudiable
Ok, I will try it!Sound changes is unaudiable
Many thanks..
Arif
New to this thread and would like to start at square 1 with SR50 but can't get BF420/421. Any suggestions for direct replacement (ZTX457??). See these were dropped in versions of SR100/SR200. Thanks
Use BF471/472 or BF871/872 instead BF420/421,
Hi Apex can you help me, how can i make protection on rs200 like on ax20p-ax14p
thank you very much
Protection circuit from AX14P can be add on any amp, and on SR200 also.
Thanks for the quick reply. Unfortunately, the recommended replacements are even harder to source here ie BF471;s/871's! Can you suggest new alternates or a supplier? Maybe I should skip the SR50 and move to SR100...but I would like to start slowly,
MPSA42/92 can be use, but pins are E-B-C instead E-C-B (BF420/421)
- Studio Reference Amplifier
