Hi all,
I've searched the archives and found some useful threads from a few years ago but am still looking for more feedback on tools for building speaker cabinets. Basically I'm looking to get as few tools as possible to get the job done while still ending up with solid cabinets.
A little background first. I'm looking to build some new MDF cabinets. I have a pair from many years ago that have served me well and were built by a local woodworker. They're two ways and I'm looking to insert my RS-52's in between the woofers and tweeters. I took a woodworking class hoping to build the cabinets in the class but got sidetracked playing around with non-speaker related projects and didn't quite finish the cabinets. What I ended up with, I'd regard as good practice, but not what I want to use for my speakers. I decided against taking the class again for a couple of reasons. For the price of the class ($150 for 8 sessions) I could invest in some tools (especially a nicer router than the one we had in the class). Also, I know I'll be building more than one pair of cabinets in the future so it seems like a better investment to buy some tools and build things at home than fork over money for the class over and over again to get shop time. The table saw we had in the class was definitely a lot nicer than I could afford though….
Now for the constraints:
I've got enough more space for a table saw (or radial arm saw) and not too much else. I already have a descent router fixed/plunge combo and a jasper jig. I was thinking about getting a table saw. I've got lots of conflicting feedback on that. A friend warned me against any of the inexpensive (ie. <$300) table saws for cabinet building and cross cutting. Another raved about his cheap Ryobi portable table saw, but he hasn't needed to use it to build speaker cabinets. For what it's worth, I'd like to use rebate joints. I've seen the Ryobi BT3100 enthusiastically recommended here and at other sites, however it looks like they've been discontinued. Is there anything similar around today at <$300 prices?
I've also looked into getting a hand held circular saw and using a guide to rip and do cross cuts. That's definitely a tempting option as it would take up less space than a table saw, and would be a lot cheaper than a higher quality table saw. However, can a relatively inexperienced woodworker like myself get the required accuracy going handheld with a guide to build a cabinet that fits together well? I guess I could try it and see how it works out, but if the time and money is better spent starting out with a table saw I'd do that. I haven't cross cut on a table saw yet though, I'm not sure if it would be workable to go without a miter saw for that.
Another tool I'd like to avoid if possible is a drill press. The hand held drill guides like this one Sears: Online department store featuring appliances, tools, fitness equipment and more that let you connect a hand held drill look tempting too, but can they work well enough for cabinets? I'm not sure if even this is necessary as I've had good luck so far using my handheld to drill holes for binding posts and subwoofer mounts. However neither of those jobs needed as much accuracy as I'd expect would be needed to drill holes in a front baffle with smaller drivers recessed and t-nuts or similar instead of wood screws.
Anyway, any feedback, experience, or alternatives would be appreciated!
Dan
Dan
I just made a simple utility cabinet using the shop where I work. I used a table saw for all the cuts. I ended up with simple joints by cutting a rebate the panel thickness wide and through 3/4 the thickness of the mating panel. (4 such edges top and bottom, 2 such edges left and right side and straight cut panels for front and back. Once I set the blade depth I probably made 10 cuts each edge to create the rebate.
When I was a kid my dad had a radial arm saw and did everything he needed to do. I think they are better for cross cuts than ripping but you can probably get by. I think a table saw is a little more universal. Certainly nicer for the rebate opperation since, if the material bounces, it is away from the blade.
I'm sure there is something to buying a better unit if you can afford it. Condition is also key, so a well set up and maintained saw will probably outdo a better brand in poor condition. I would also check the used lists because I'm sure this is something that people nearly give away when they are moving (anybody want a 4 x 5 enlarger?).
Cutting larger panels is much more of a challenge than smaller panels. Some use the small construction type saws, but I can't imagine piloting a full 4 x 8 sheet across one. If I needed to do that I would probably precut the sheet to rough size. Our local home depot has a panel saw and you can cut sheets down at the store (as long as you purchase them!).
I don't know if a drill press would be of a lot of use. I think a router for woofer recesses would be the second tool to get. Either one of those circle cutting jigs or perhaps make a series of outside circular templates. For the utility box I will use a jig saw and surface mount the driver. In the past I have used milling machines and fly cutters, but that was at a well equiped machine shop.
Don't forget band clamps or bar clamps and a large square for assembly. A palm sander because they are cheap.
Thats really all you need to get started.
David
David
^ .. good advise. If you've got room for one stationary tool ... get a decent 10" table saw. Older Unisaw(delta/rockwell) would be #1 choice ... check local auctions. The smaller units you see are "toys" .. sorry but true. They do the job but running large panels on them are a real "treat". Figure on fabbing up some "dead men" either way. (Dead men are basically saw horses build to table top height. Smooth, narrow top edge for less panel resistance while moving through the blade. Lacking an outfeed table/space for one ... make several to "help" keep the panels level while sawing. Keeps you from trying to balance these and cut at the same time ... ie. unsafe)
Radials are OK .. just a PITA to setup if you intend on doing "everything" with them. Change overs diminish accuracy. If you can't afford a real good one ... these are pretty much a waste of space. Nothing that can't be done faster and more accurately on a table saw.
Don't forget band clamps or bar clamps...
Choose what you think you'll need, then add 50% more. You'll still find you haven't enough...
One thing you don't really think about until you go to build is clamps. Lots and lots of clamps!
With a little ingenuity you can do a lot with minimal tools, but you can never have enough clamps.
Seriously - I didn't give it a thought starting out, but one of my major headaches was getting enough clamps.
Unisaw
I have one. A 50's vintage beauty with the old 1 hp motor which somehow equals 2-3 hp today. Something about induction/repulsion, the tool man says. Anyway. There are considerations. Old school table saws are right tilt, unless they are powermatic/craftsman/others, which means they are intended for crossscutting with a miter guide. Modern saws have gone with the left tilt arrangement, since most of us have overarm tools, chop or slider or radial arm, which make the table saw primarily a ripping tool. As such, right handed operators find right tilting saws counterintuitive when bevels are involved. If you have a crosscutting tool, don't buy a right tilt table saw.
I just installed a sliding table to my ancient unisaw so I am excited about being able to crosscut 25" dead on 90 degrees.
Woodworking is tool intensive, by the way.
I have built entire PAs with a circular saw, a non-reversable single speed drill, and a jig saw.
I now have a decent table saw, but the fence only goes to 25", so I still end up using a circular saw and a 48" framing ruler with two "C" clamps as a guide for many cuts, a poor man's panel saw.
If I measure the position of the guide ruler accurately, the cuts are perfect.
I'd invest in a bunch of clamps (you can't have too many) and additional drills and routers (to avoid having to change bits so often) before I'd buy a table saw.
After seeing many people with missing fingers (while getting mine repaired :^( ) due to radial arm saw accidents, that was the only one of my father's tools I chose not to inherit.
A miter saw does all the things I'd ever use a radial arm saw for, and does not have the runaway potential the radial arm saw has- my Dad told me of one work accident where the entire motor/blade left the arm and blew through a wall, fortunately no one was hurt.
Don't forget a good shop vac, they can be rigged to suck up a lot of the dust before it hits your lungs.
A small drill press can be very helpful for drilling perfect countersink hole depth, and can be used as a poor man's lathe with some Jorgenson clamps set as tool rests.
Combined with a router, a drill press can do some very interesting things quickly.
Good hearing protection is a must, wish they would have taught me that when I was in high school shop, more of my hearing loss is due to early power tool use than 120 dB shows...
Art
Art
I had a radial arm saw at one time, but wound up selling it. I only had it spit a piece back at me once, but that was enough.
I picked up a Ryobi BT3100 some years ago, and I'm glad I did. It is small enough for my smallish shop, but big enough for most cutting jobs. Full panels I cut just as weltersys says, with good results.
Other than that, a router, with a Router Buddy Circle Jig from Parts Express, a drill, and some squares, etc. A miter saw is nice for precision cutting smaller pieces or reinforcing pieces to length, but not a necessity.
Actually I think the most versatile tool in my shop is the 16" Delta band saw, but again not a necessity.
If you're going to build a few cabinets over a few years, I see no reason to spend money on a table saw that will just take up a lot of space and only be pulled out and used occasionally, especially when you consider that the first few cuts from a 4x8' sheet will probably have to be made with a hand saw anyways unless you have some extra help.
The price of a table saw can buy you a great straight edge, lots of clamps, and a nice start to a cordless tool collection. (get a cordless drill and circular saw set to start). Modern 18V cordless circular saws will cut 3/4" MDF without a hiccup. Yea they won't let you go ripping through 4 feet of it in 2 seconds flat, but they have no problem with the material load and are less hassle than the corded jobs because you don't have a cord constantly getting hung up on clamps and legs and generally getting in the way. Also the lower RPM cutting results in a nice row of deposited MDF dust rather than a whirlwind of it all over the garage.
When looking for a router, I like the Porter Cable units with the full range helical worm fine feed design. I'm not sure if other brands make a similar design but IMO it is great. Units that come with collets for both 1/2" and 1/4" shank tooling are also preferred, however, none of this is necessary. The only important thing I recommend, is ensuring that the design allows for a fine feed, and has a very good locking mechanism to hold a cut-depth. I have an oldish SKILL brand plunge that is basically useless because the mechanism that is supposed to lock the position doesn't hold under vibration.
Art [Weltersys] above made a suggestion about using a drill press in creative ways (as a lathe, etc). I can't stress enough how much you should not do this. Use a drill press for drilling only. Without a drawbar (like a mill/drill), applying a lateral load to the drill press spindle is asking for an injury. Lateral loads are a great way to drop a heavy chuck that's spinning 3600RPM. A light duty benchtop mill/drill for a few hundred dollars on the other hand, can be used in many creative ways for light jobs safely. Though- you don't need that to build speaker boxes (don't bother unless you have some other uses in mind).
Eric
Eric
Thanks everyone for the responses. I do already have a router, jasper jig, some clamps (although maybe not enough), and a cordless drill. I'm encouraged to hear that a circular saw might be a good alternative to the lower priced table saws. One option I had thought of but didn't really take too seriously was just to cut panels in 2 or 3 passes with the router and an edge guide or ruler. The speakers I'm building aren't too big, maybe 15-17" is the maximum dimension.
Dan
Dan
saws
Routers do not want to cut straight. It can be done but it's not what they're for. A decent circular saw, whether mounted under a table or hand held, is many times more efficient. Pawn shops are packed with quality tools these days.
As for the radial arm, a correct zero or negative hook blade is crucial. Those terrifying runaway moments are due to several factors, including dullness and user inattention, but the proper tooth geometry is not well understood. A freshly sharpened negative hook blade will just sit there in the middle of a cut. Table saw blades, having 10-20 degrees positive hook so they'll perform correctly in their application, will climb right out and try to get you. Just because it says "crosscutting" on the package doesn't mean anything more than how many teeth it has.
Fortunately this information is less obscure than it was 40 years ago. Just keep your fingers, and your hearing, and your lungs as the top priorities, then the projects themselves.
Yeah I'm a tool fool.
Hi all,
Dan
This is my choice. I use a circular saw and various guides. There are straight edge guides that work very well with just one hand to clamp them.
I think the key to good cuts is to know your saw. How far, exactly, from the fence is the blade? What's the kerf? Which side of the cut do you want the kerf to be on (or, which side of the cut is the waste side)? Also, checking to see if the blade is parallel to the edge of the shoe (or is it foot?) of the saw is important. I took a file to mine to make it as perfect as I could.
Finally, I recommend using a marking knife. These are special knives that have only 1 bevel on them, so that you can put the mark exactly up against the edge of the square or ruler.
cutting guides
I use them all the time. Make my own since, as admitted already, I'm a tool fool and therefore have all the pneumatic fasteners, like a fine wire stapler that shoots 1/4 to 1 inch narrow crown staples. Festool, the current darling of well heeled woodworkers, has a lovely system of table/guide/saw which makes an old school rig like my Unisaw+sliding table+long fence look bloated. Oh well: I'm old and a long way way chronologically from school. When looking at portable saws be sure the base is flat. The good ones have magnesium base plates. Carpenters tend to drop their saws on the ground which leads to warped bases on used saws. Square cuts are unlikely with a bent tool.
I think it takes $500 minimum for a new table saw to equal what you can do with a portable tool, guide, clamps, and attention, and you'll still need the portable and guide to deal with full sheets. Start there.
Ok, scratch the idea to use the router as a poor man's table saw. I got some feedback on that idea over at router forums and it doesn't sound like the safest thing to do. A circular saw and a guide is starting to sound like the best option for me. Dirkwright, thanks for the suggestion of the marking knife. I hadn't used one of those before and they sound helpful.
Dan
Dan
Dan
You're welcome. You can only cut as accurately as you can measure, mark and layout.
I had a nice radial arm saw and got rid of it. The versatility is attractive, but a table saw is vastly more accurate and more suited to cabinet work. I wouldn't use a portable saw and guide unless there was no other choice. If you go that route, be sure to have a good Stanley #5 or larger hand plane and know how to sharpen it. (I wouldn't trade my #5 for anything.) Truth be told, you can do 1st rate cabinet work with nothing more than hand tools! Still, I'd recommend a mid-range or better floor model table saw (Powermatic to Unisaw), a Porter Cable router and lots of clamps. Then you need finishing related stuff like sanders- I'm too lazy to do that by hand! Also, the saw fence is really important- don't skimp there.
The router kicks up too much sawdust and makes too much noise to use as an everyday cutter. It makes a great trimmer, however. I second the suggestion to use end-to-end guide clamps and a quality circular saw. The clamps go up to 60 inches, meaning you can rip boards five feet long accurately.
Keep in mind, most of these cutting tools are only useful for straight, unwarped plywood. (Store your wood flat, BTW.) If you are going to get into hardwoods, you need either very well flattened and milled stock or you need a jointers, perhaps even a planer. You may be able to find a custom lumber house near you that can supply matched planed and sanded boards, though.
I have one of these. I need to order a smaller one.
http://www.amazon.com/Clamp-A-50-50...YV40/ref=sr_1_3?ie=UTF8&qid=1331748953&sr=8-3
A big sliding table saw is a thing of beauty...but you don't have room for one and neither do I.
Circular saw and guides work well, cost much less and take up much less space. I found it worthwhile making several guides of various lengths to suit my saw, with the offsets of my saw kerf marked on in thick pen to have one less thing to forget. Use good clamps.
I've got a couple of pairs of sash clamp heads, the things you stick on pieces of wood to make sash cramps, prefer them to full sash cramps for some reason.
A biscuit jointer is well worth having, good strong joints, quick and easy to use. Carefully keep the biscuits dry til you're using them though, otherwise they can swell to the point of being unuseable (they're meant to swell in the joint a little, from the water in the glue, making themselves tight I think).
- Design & Build
- Equipment & Tools
- Looking for more thoughts on cabinet building tools
