Xoc1 6F TH
First I want to thank Xoc1,Tb46 and others for this tapped horn design.
I have everything ready and building is on the way.
I will be asking questions if i come across any trouble.
My first question is about angle cut.
What are you going to use?
Marine grade?
After working with Baltic, and other lesser plys, I since have willingly paid the extra $ for Baltic because it is a joy to work with. (machines nicely, cuts easily without too much splintering, sands to a nice finish very quickly, very few voids etc etc)
Hi Kornylike
Checked out your cutlist
Part 4 Which I guess is the top panel is short (Suggest 32-25/32") :eek:
Part 15 Top Back reflector is missing :bawling:
Sheet 2 of the drawing is labelled with numbers for reference to cut list and angle sketch added.:)
Regards Xoc1
  • 18in 30hz - 6 Fold TH Assy Inch Plus.PDF
I was going to ask about the angles a couple weeks ago while cutting the test box panels, but didn't have internet access. Glad I figured it out (exc the sharp S1 angle piece - I waited on that one).
I got sick the other night, so I'm hoping to get my test box together very soon (after the weekend perhaps).
Kornnylike, are you building yours with the 2:1 compression baffle cut out or an open baffle?
