TO-3 SYMASYM
Gentlemen, I will be able to offer you lower prices due to quantity discount.
I will also order FUTABA MPC74 0R22 emitter-resistors.
Find attached the current order list.
Please transfer the total amount of money to my PAYPAL ID: RRozek@t-online.de
I would like and order the PCBs on Monday, 12th of March.
Best regards - Rudi
Rudi
I have a very simple automatic fan control schematic that works really well. Is there any chance you can make a few PCB's for that?
The fan speed increases with the temperature, when first powered on the fan runs at full speed for 1 second(you need to add 1 capacitor 1000uf/25v in parallel with the NTC)
Temperature-controlled 12V dc Fan - RED - Page109
I think this would be a circuit that many need inside their amplifiers
Vlad
I would like to run this amp (with this board) from a 28-0-28 VAC transformer (because that's what I have.) I know the specified value is 25-0-25 VAC, and that the original symasym (e.g. AAKs) can run up to 50V rails, 35-0-35 transformer).
Can someone tell me the tweaks to the Cap-multiplier circuit I would need to make, to ensure safe operation at the increased voltage. I did read the assembly guide (or rather had it translated via Google) but it was unclear to me what changes must be made.
Thanks for your time.
Ryan
Ryan,
a transformer with 2 x 28VAC secondaries will give you about +/- 39VDC (roughly) after rectification.
Please take in account deviations in mains voltage, ..., as well.
This voltage may be critical for "sensitve" input transistors, like the 2SK170.
I therefore recommend you to solder the cap-multiplier and use a Z036 Zener-diode so that the frontend's voltage will be delimited to 35.3V (roughly).
And please: use 50VDC rail capacitors.
You should not have any problems then.
Best regards - Rudi
Whilst the subjects at the moment are Tx and cooling, I have been trying to find info. on the suggested PS requirements before the board. I would like to know the suggested VA rating for both two Tx PS and Single Tx. Also would like to know the recommended heatsinks for this amp, preferably by a makers code and measurement. [I will be aiming at building a totally standard stereo-amplifier.]
Many thanks,
Brian
Rudi
PCB looking good
Few things to consider: most fans need ~200ma to operate and PCB transformers are wery low power. Maybe is better to have a chassy mounted trafo instead of PCB ? Two decent fans require 0.5A minimum (depends on the max RPM).
Maybe consider some jumpers to solve the routing issue? Don't think anyone would mind a couple of wire jumpers on the pcb :)
Don't forget the 1000/25v capacitor parallel with the thermistor (I think that is on the PCB already but I am not sure :) )
Regarding the zenner diode for the front end of the amplifier (35 or 39v ?) can you post a photo with the position where it should be located? Can we substitute the small transistors with some higher voltage equivalents (pin to pin compatible preferable) to avoid overvoltage issues?
Vlad
