Hi all a bit off topic but....
We have a new clock out (C3) and have 25x C2 still available. If anyone is interested I am going to sell them on with a large discount. I can do them for £99 + postage. Let me know if anyone is interested.
cheers
Brent
Thats pretty good mate.......can I get a refund on mine LOL!!!
Seriously, thats a great price, that C2 is very good and can clock the DAC, Decoder and servo all at the same time!
Anyone know where the best place is to purchase the LM4562HA amps at in the soic form? Thanks!
The HA refers to the pin out
TO-99 = HA
DIL8 = NA
SOIC = MA
Brent at Fidelity Audio or "Thomo" on this thread may be able to help.
Was using 63 KI as transport
All of a sudden, the player stopped and showed the TOC
Error code showed 10 and sometimes 02
Nothing wrong with ribbon cable
Which item should I replace
Help apprecited
What have you changed recently? Poss a clocking issue. Does the dosc spin fast or backwards etc?
I was wondering about those op-amp caps. I use 470uF BG N series there but I didn't audition many alternatives and I'm starting to question whether they were the right choice. The ones I've heard recommended most for that position in the past are BG STD series. I might have some of those. Should I switch them?
TO-99 = HA
DIL8 = NA
SOIC = MA
Thanks Brent
I remove the 7909 and 7809 reg for the servo because I suspected
they were causing skipping. No problem, was playing and the faults came as described.
Check the clock, also no problem, output 16.9Mhz
Very common fault, but I think is difficult to solve
Just say Brian next time, then you'll be half right if it's either of 'em
That will do lol
Brent
Can you imagine the superbeing that would be a Brent/Ian hybrid!!! Lmao!!!
1 Part brilliant & 1 part noobatron
I'm not the noobatron BTW despite popular belief!
Brent
Bald! He thinks cutting your hair is a sign of weakness LOL
Lee is already a super hero. Better known as 'Sloth Man'
Brent
Brent
Clearly the southern bit would be better looking than the northern bit!!!
The Southern bit would wear lots of coats on a night out too! LMAO
Brent
He appears to be wearing a nice jumper!!!
- Digital Source
- Marantz CD63 & CD67 mods list
