Originally Posted by GentryBa http://www.diyaudio.com/forums/pass-labs/206756-f5-turbo-circuit-boards-post2915803.html#post2915803
@UKToecutter:
Maybe it would be the best to make a list of all the guys who would like to have PCB's?
cheers,
matthias
Matthias,
I already have.
Please see my signature. There is a link to a list
oops, ok... sorry
maybe I add some more in the next few days!
matthias
Also available in the UK. Email for a price.
Heatsinks: 7000 series - 7200HS
http://www.gdrectifiers.co.uk/uploads/Heatsinks_for_isolated_modlues.pdf
Wow they come 12 inchs tall ( 300MM) ... Jacco won't like that ...
Do the math , it cost more to "build" 2 chassis than one, no matter which way you slice it . Here we can buy used exotica for 2K, so guess what spending 2 K for DIY does not make much sense.
Precisely, this will keep going around and around , i guess most here have never had a 100 watt class-a amp , it's monster size, monster heat , monster consumption.
Whats the cost on those sinks .... ?
You mean more convenient, Hard to make room or justify 4 mono chassis plus cost...
does it? when the stereo amp must be 4x taller? thats twice as much heatsinks as for 2 monoblocks. and the heatsinks are the most expensive part of the chassis. only topp and bottom plates that will be more expensive on monoblocks. and thats about 30$.
5.5 m/s air velocity.
Reduce it to 2m/s and you're scot(t)-free (t = including AndrewT).
increase it and you can dry your hairs while listening to finest music!
I am a big fan of the idea of separating the output boards and input boards. This would allow for people to make the standard SE build, mono-blocks and balanced cleanly. It sounds like there are a number of people (myself included) who are looking to do balanced builds, and a separate input board could be made to support a balanced option (probably would only need a few jumper locations). It also makes building mono-blocks more straight forward as well.
Separating the input and output boards would provide the maximum flexibility, at the expense of a little added cost. In the scheme of things, the added cost for the PCB's would be pretty insignificant.
My 2 cents.
I agree, and allow for 2,3,4 outputs possibly - in an ideal world of roll your own need PCB.
OK chaps
Input stage PCB
Input stage PCB
N Channel board
P Channel board
P Channel board
very nice Andy.
Now the voting for what GB to do can begin
GB?
- F5 Turbo Circuit Boards
