thanks for the comment mkubawat.
thank you dear...
you remember me...
regards
ees...
sir apex what can i use to replace the ir2117 for the step driver of your h900..i have build 3 of your b500 and i am planning to build an h900. thank and more power.
There is no replacement for the IR2117, use circuit with TL072 step driver.
Hi Remle,
Did you make your own board?I cannot find ir2117 from your board...
regards,
drowranger
yes i make my own board.
also i cannot find IR2117 thats why i build this version with transistor driver
regards
Elmer
my H900 with -/+47MV -/+94HV
Nice work, 80VAC on output is 1600W on 4R load. I suggest limit on 60VAC it's 900W on 4R or 65VAC for more than 1050W on 4R. Speaker impedance can drop for different frequency, and power increase more than 50%, with only 4 pair of outputs it's risk.
regards
Elmer
sir can you post your schematic version of you h900 using a trnsistor driver for the supply..
regards.
regards.
schematic on page 135 post 1346
80vrms how much load did you use? is it loaded or no load ??my H900 with -/+47MV -/+94HV
- 900W H-class PA Amp with Limiter
