Simplistic MosFET HV Shunt Regs
Some says tube rectification will cause the input voltage variation to *any* regulator may result in it dropping out of regulation. That's why SS rectification is more preferable.
I am not Salas, but I can assure that all Salas shunt regs are working perfectly with tube rectifiers.
This has nothing to do with solid state or tube... a tube rectifier drops a certain voltage , so do take that into account.
Get PSUD2 (free) and start fiddling.. just choose your Vin at least 20V higher than your Vout and you won't have a problem...
Regulating to 400V might be borderline and has been answered numerous times, but I'll leave that one to the Master. ;)
Joined 2004
Testing dual SSHV2.
Raw supply: 240V ct - AZ1 mesh- 5.4uF -10H (100R) - 47uF -3H (80R) - 220uF -> 254V
20mA CCS, 7mA load (#26 preamp), 220V.
Noise below 1mV (in the other side 2.5mV)!
Was able to back down the drop across test point, but with inly 16V out of prefilter, i am dropping almost 12V across 220r resistor on prefilter. 500mV across R1, 3.5 across r2 of sshv2 is yielding 160 mV across r5. Diode ,easuremnets reflect gate voltages.
When i first fired it up, i fried r1 along with 220 on prefilter. Did i fry the q1 in the process?
