Studio Reference Amplifier
Leonatax, you can use BC557,BC556,BC560 and BC546,BC547,BC550. Just dont use BC548/BC558. They are only 30V limit. There are also some 2SC/2SA, that can be used.
Voltage limit will depend on the position the transistors are in.
For Q1-Q2 you can use better, lower voltage transistors, even dual types if you can find them. Like MAT01 and MAT02.
This is my amp from 80', modular drivers and protect pcb only caps is too big to be fit on amplifier motherboard. I considering to use this design for 'Studio Reference Amp'.
I find schematic of this old amp from '80.
