MPP
Here are pictures of how far i came. I use a mix of FKP2 10nF, RIFA PPS 1nF and the mentioned Pollin Styroflex so it is a mixed dielectric.
Sorry If I did not get here earlier
Another 60 hours week at day Job
Here is the first take for the pre regulator.
I have used 15 mm foot print for the 100 nF
and there is space for 2 sizes of 2.2 Homs resistors.
Earth plane can be made better
and Pads for the 1uf and 100 nF Caps will need to be aded depending on component choice
+ links to Choke and 100 nF X1 caps
Buy Paper PME271E,PCB mount,100nF 300Vac 20.3mm Evox-Rifa PME271E610M online from RS for next day delivery.
WUERTH ELEKTRONIK|744841210|CHOKE, COMMON MODE, 0.1MH 1.5A | Farnell United Kingdom
  • PreRegulatorPCB1.PDF
That can be changed no problem at all
What size PCB would you suggest?
Is the board for Paradise 160 X 220?
I assume that keeping dimension (at least the one where board connect the same may be more aesthetically pleasing?
I tried to keep Caps/resistors close to Diodes. With a bit of space just in case things get warm
Are the paper Caps ok I assumed that X1 class may be needed?
I am very happy to make any changes
mad_z, thanks for the zeners.
You are welcome!
If anyone needs bzx85c zeners they are easily available at this place:
S?AWMIR Electronics - Sklep elektroniczny. Dystrybutor cz??ci i podzespo?ów elektronicznych.
Unfortunately the shopping page is non English - I may buy quantity and send in envelopes if anyone has problems sourcing anything good at their location - but I guess most of big boys like farnell/buerklin/rscomp stock good parts anyway...
Wish I had the PCB boards too at my desk:) now.
You are welcome!
Mighty good of you and my bit.
Just got a bit of Kerafoll 86/83 that can be cut in to strips.
Berquist stuf is ok but...
