Simplistic MosFET HV Shunt Regs
SSHV2 B.O.M.
Q1-2 DN2450
Q3 IRF840
Q4-5 KSA1381
Q6 2SK117GR
IDSS? HEATSINKS FOR IRF840 & MINI-HEATSINKS FOR KSA1381?
D1-2-3 Z12V 0.5W
D4 LED VALUE?
R1-2 100R
R3 330R
VR4 500R
R5 10R
R6 1R86
R7 100R
R8 1K
R9-10 68K 2W
VR11 500R
R12 1K
C1 0.33uF
C2 10uF
Salas.....SSHV2....R8....in my application should I use 1K or 1.8K...or other value....thankyou.
The LED can be RED, or ORANGE, or GREEN, or YELLOW.
Each colour comes within a range of voltage and that voltage range varies markedly with production method and manufacturer.
Expect 1.55V to 2.1V as the range within which all those "normal leaded end" LEDs will fall.
You have to measure the as built circuit to confirm what currents are passing individual components. Then adjust component values if necessary.
Today I decided to finish my second SSHV2 for the pre I am building.
Both shunts on the test bed working nicely, and voltage is very stable.
Just be careful if you use long cables without any decoupling. I managed to get it into oscillation with very long test cables. A cap near the input and everything is fine. Nothing burned this time, but future builders do not take the risk.
Joined 2009
Just curiosity, wich pre are you building?
