Waveguides and horns
Stereolab is a solid surface (SS) horn. Autotech made first SS prototypes. Is GPA 399 Altec 288 replacement?
Jacek I don’t know what SS horns means but the Stereo lab are plain round Tractrix horns with truncated profile.
GPA drivers: http://www.greatplainsaudio.com/hf_drivers.html
I bought the 399 but with the lower power aluminum diaphragm, part number 23763, so I got a kind of modern 288 called 399 ;-). The 399 model uses a stronger Pascalite (aluminum )diaphragm.
Sorry the 399 with the lower power diaphragm should have been called a 388 not 399. This is not a regular model but GPA can do it on order.
jzagaja please build a reasonably priced neo 555.
A couple of pictures.
jzagaja
Going through the pages looking at all your efforts. Please consider a neo 555 updated to match your horns. It doesn't have to use any patents. Just be roughly inspired by one. The world needs this most I think. I do anyway. Look to goto for inspiration. Why stuff with ferrite drivers or diaphragms for that matter. Use one from another driver that is available and proven. Surely if I can buy a Chinese compression driver off ebay for 30$ why cant A Chinese neo 555 driver be made for say 300$
Dr Geddes
If you are still reading . I know you have probably have forgotten more then I will ever learn. And most likely have better things to do then explaining this to me . So feel free to ignore this question. Or perhaps some one else can answer this question. But if you may. Despite the tests that have been done. I am not still convinced distortion is a non issue. How can 2% plus distortion levels be a non issue? OK maybe a group of guys cant hear it but still I would like to buy a driver that was optimized for lower distortion then that. Perhaps it is not possible with compression driver technology?
I have been in communication with a local driver designer here in Australia that wont even consider compression drivers because of their distortion levels.
