What power is your 12 inch speakers?
What is the max voltage for b500 with single pair transistors, Sir? I want to try build it. Thank you very much sir
Shreya sent me a PM saying "How".
I had to ask How - What?
It turns out he was referring to post 1825 but did not bother to tell me that even when I took the time to answer his PM and ask for clarification.
Today I have stumbled upon "work it out" and now realise I was wasting my time posting
http://www.diyaudio.com/forums/solid-state/164208-500w-pa-amplifier-limiter-36.html#post2775301
It appears Shreya can't be bothered to read this thread. Not even just 3 weeks ago!!
Shreya, don't ask me for anything again, not privately, not here.
APEX B500
components placed and ready to the test
ImageShack® - Online Photo and Video Hosting
APEX B500
Sound is nice,no noise but getting very low sound
Bias is 4.5mv at 0.33R may be 13mA each output
DC offset is 5mv
I have used 2sc4793 2sa1943 instead of all mje's and R4-47K,R22-1k
PSU: 50-0-50 AC (two 25-0-25 in series) 10A=====72-0-72 dc at 20,000uf total
I have used mobile phone as input (350mV)
but sound is very low,when i measured output with multimeter its getting 16v RMS only
Is this normal?
DC offset is 5mv
Is this normal?
DC offset is 5mv
Is this normal?
You need preamp (5X gain), 350mV is to low for full power.
DC offset is 5mv
Is this normal?
yes, you have a gain of x45, a 1volt input should drive your amp to almost clipping.
Ok sir
Thanks for your reply
I will test this amp in line level
what happens if I decrease the value of R22
and when R4 increases gain increases ?
Ok sir
Replace R2, use 1k instead 10k and gain will increase.
- 500W PA amplifier with Limiter
