What kind of resistor do you use?
Joined 2004
Since someone brought up ferrous parts...I have often wondered why there are resistors with ferrous (steel) leads, in fact sometimes you can even get the same part with copper or steel leads. The reason is that steel is a bad (at least worse than copper) thermal conductor. By using a part with steel leads you can "shield" the rest of the surrounding circuity from its dissipated heat. With copper parts in turn you can (ab)use pcb tracks as heatsinks...
Copper end caps bent too much when the leads were bent and could open up the contact with the metal film.
I'd guess a lot of heat dissipation is via the leads and PCB traces. Design accordingly. As for the thermocouple effects at the ends, don't mount resistors standing up and try to make the thermal impedances of the traces equal. IMO, any design that discolors the PCB after a few years is a bad design- use bigger parts and space them off the PCB! Remember the old Dynacos that used dropping resistors that turned the PCB dark brown? I've also seen metal oxide resistors operating within their power ratings unsolder themselves and fall off the board. Maybe that's the real meaning of "dropping resistor".:eek:
Joined 2004
I just came across this plot and thought I'd share it here since it's something I haven't seen too often in datasheets...
The part in question is a 3W 5% 750V 250ppm metal film resistor. The datasheet (http://www.vishay.com/docs/28729/28729.pdf) is featuring an impedance plot where one can see that the part acts purely resistive up to 2MHz. I bet Magura would like these ;-)
