Inside the S2
Yes, I was cheating
The driver tube is a 10Y, usually a power tube. Not a sissy by any means.
BTW, this is one signal chassis of the GM70 amp, there is a another similar chassis for the right channel, and a big chassis for the power supply. Nelson would need a shrink ray to fit inside the S2 case. And the GM70 system weights about 5 times the S2, so an anti-gravity belt would also be required.
naah .....
you're cheatin' ;
Papa will not put so sissy driver in there ....
Yes, I was cheating
I have those sissy drivers ( 10Y ; still can't decide what to do with them .... line stage or pre/driver stage for Le Petite 211 amp ) ......
regarding size/weight issue ... remember this one ( it's in Papa's possession since I send it over there ....... )
Inside the S2
Hummmmm, that bag is in the S2. Now I have to wonder.
A little more listening
The amp continues to surprise me. In some ways it sounds very much like a tube amplifier, but not altogether. This is just a brief note, as my reference speakers are not available and the speakers being used are not of extreme resolution.
The amp sounds "big". There is a large, open soundstage that fills the room, that is the first thing that you notice when the amp is plugged in. The effect is a little intoxicating.
Then there is the control. My usual collection amps never brought this particular pair of speakers to life. (I have been playing with a EconoWave like speaker to see what I could do with it). But the SIT seems to bring a lot more control & detail to the speaker.
Sarjan has noted, the speed is obvious. Although the initial reaction is that it is too fast, you begin to realize over time that the other amps are a little slow. Real music can be very fast, especially with the close miking that is used for most modern recordings. Sorry ZM, I do not know of any tube amp that can do this, so I do not think NP stuck a 300B in there.
The tube sweetness is present, yet the presentation is very clean. This is like a very nice low distortion SET.
The one thing that Sarjan missed, that I find very important, is the relationship between detail and dynamics. Many amplifiers bring detail to the forefront, and they usually have squished dynamics. (yeah, squished is a technical term!) Heavy use of negative feedback softens dynamic contrast, and this allows the details to be presented at similar volume levels to the main harmonics. The effect is to make everything sound super-detailed and wholly unnatural. The SIT presents details, but with proper dynamic contrast. Details do not poke you in the eye, they just naturally unfold as part of the music.
More later.
More later.
The chances of anything coming from Mars are a million to one
Oh Yeah ?
Die Fritz van die Suid-Afrikaanse veiligheidspolisie het ander gesê !
Listening with the big rig
So the big system is back up and running. The Lowther field coil driver, with a RAAL dipole ribbon on the top in an open baffle configuration. The bass is provided by a Rythmic subwoofer built into the baffle, with a 80 hz low pass filter.
Because the woofer is active, and not driven off the Rythmic, I will revert back to the first system to talk about the bass. That system used a Tone Tubby 12 Alnico, so deep bass is not present, but what was present was quick, well defined, tuneful, and with the proper amount of weight and umpf. It was at least as good as any other amplifier I have had with the Tone Tubby. The lone exception being the F1-J which, by virtue of being a current source, provided deeper bass response. Surprisingly, the S2 low bass was somewhere between that of the F1-J and a J2 in terms of extension. I do not know why the S2 extended the bass response, but it did.
I was initially afraid that the speed of the S2 would be overwhelming with the Field Coil (FC from now on) and the RAAL. Both of these are exceedingly fast. Instead, there was no apparent jump in speed, things just resolved very nicely into music. Just plain, natural, big, open music with no sharp edges. One of my classic test of a system is how long can I play music before it makes me want to turn it off. Pretty well went for 12 hours before my wife informed that I would be going to bed. Could have listened for longer. What this tells me is that there are no sharp edges, i.e. ringing and other artifacts that can create a the false impression of speed. These cause listener fatigue, and it was not there.
What changed in the system was the feeling of space. Images were big, yet precise. A definite "I am there" as opposed to a "they are here" type of sound. The FC/open baffle combination creates a large soundstage with most amplifiers, but the S2 enlarged and clarified it at the same time. Neat trick.
Dynamics were totally natural. As noted earlier, the harmonic overtones and details of the music were all present, but at there proper amplitude. The net effect is a very natural flow to the music. Playing big, bold music worked fine, no congestion or slowing down when playing loudly. The FC is about 98 dB efficient, so I did not expect a problem. But even some larger amplifiers tend to shrink down when driving complex passages and music. The S2 showed no strain whatsoever. The difference between loud and soft was simply volume, nothing else.
Female vocalist are totally natural. Just there. You can easily tell the difference between young Ella and old Ella, with the shift from sweet and soft to a more husky sound over the years.
Transparency of the amplifier was somewhat ruthless in revealing upstream errors. A slight mistracking of the my phono cartridge, which I did not hear before, was not only obvious, but annoying as hell. As soon as the phono system was properly dialed in, everything again became musical and natural. A change in the digital front end, from PowerMac/Lynx L22/Pure Music to the Bryston BDP-1 and Havanna DAC, showed both the advantages and problems with each.Most digital recordings lack warmth, the low resolution format wipes out a few digits too many. The Havana adds in a slight amount of 2nd order distortion that helps fill in what Redbook leaves out. Puts a little meat on the bones. The PowerMac/Pure Music/Lynx system is clean, and with high resolution material is pretty as can be. But it is a little lean with Redbook.
I use the Pass XP25 phono-stage, and the XP20 line stage, and saw no reason to change either of these.
A friend/audio professional was over Saturday. His parting words were "I hate you". Of course, I had to ask why, as it was out of character. The reply was simply, "Because you have sound like that in your home, and I don't."
To summarize, the speed of the amplifier is what first grabs you. But really it resolves itself to a very musical presentation. If you want to add some color to the music, or slow things down a bit, you can do that with your front end. But as far as I am concerned, it is like putting a plush suspension on your Ferrari, whats the point? This tells you the truth, the whole truth, and nothing but the truth.
Tea Bag has asked to come by for a listen later this month when he has to come to Chicago for business. Maybe he will say a few words afterwards.
Wife, no problem!
I have been married for just over 35 years. My wife is one of the true blessings of my life. She not only tolerates me and my hobbies, but encourages me and helps me. Nope, not a problem.
She won't let me turn the living room into a dedicated stereo room. And if I wanted to get picky, I could complain about that. But I choose not too.
Worded differently, my wife is better than my stereo. May you all be so lucky.
Not so serious anymore
Does that mean I can revert back to "My GM70 is bigger than your itty bitty 300B", or "My SIT is hotter than your J2" (the S2 does run really hot), or is that too far in the other direction?
Jon ..... don't be so serious ......
maybe you can use one like this : http://www.diyaudio.com/forums/pass-labs/186554-babysitter-papas-koan.html
it seems that I'll stop posting replies to you ...... I'm not so serious as you have impression .
I didn't meant on Papa's OBs
what I meant , and what's Babysitter per se is : ( http://www.diyaudio.com/forums/pass-labs/186554-babysitter-papas-koan.html#post2530023 , post #3 )
Hey, I gotta have my fun!
My last post was meant 100% in humor, not a serious note in it. Unfortunately, you could not see the smile on my face as I typed it, indicating that it was meant in fun.
That is a problem with e-mail and such - no personal interaction to let you know what is serious and what is not. I am not a serious person, and now that my wife stopped reading this thread I can make fun of her too.
Please continue, and do not worry about a thing.
- Srajan has the 1st SIT amp for Une dégustation
