DAC-ASH (dac-end 2 up date)
Getting There
Nearly at the point to start drilling the chassis, but will probably move the power supplies into their own box. The (incomplete) output stage power supply (E-I transformer, blue turret board, 2x chokes & DC heater supply (6 caps on stripboard) is taken from Thorsten Loesch's design, which is optimised for the AD1865: http://www.fortunecity.com/rivendell/xentar/1179/theory/vasfda/vasfda.html
No bypass capacitors used & Black Gate PK used for all IC decoupling. Analogue power supply uses Elna Silmic and digital uses Elna Cerafine & Oscon SP. Shinkoh I/V resistors & PRP resistors everywhere else. Minimal magnetic parts are used, so even more reason to put the transformers in their own box!
Teflon sockets, 6H23n-EB tubes, 1/2 watt PRP resistors & film/oil Obbligato output caps (large as they're driving a passive preamp) for the SRPP gain stage again taken from Thorsten Loesch's design.
Quanghao do you have a BOM for the board you sent me as the resistornumbers don´t match with the new pcb´s?
Edit:Actualy I see now this board only have one kathode resistors wheras the new board has 2/tube...
Didn´t you have any new Pcb´s to send?....
