Photo Gallery
My Lord: My quasi father-in-law makes the bases for me from Mitbeau. He orginally use to make the bases from off-cuts but lately he now has to buy new timber because I have ordered so many.
I sand the bases dead smooth with a 00 sand paper then polyurethane spray them.
The top and bottom plate are 2mm thick AL and cut by Capal. But I do all the drilling. Big job this time.
Monoblock PL509 sweep tube SEP
Hi
After a few weeks of work we now have a pair of monoblock PL509 sweep tube single ended pentode amps.
Schematic has been revised somewhat.
Here's an interior shot of one of the monoblocks.
They sound superb.:)
6MD8 tube buffer
Continuing with tv tube saga, i set out to build a tube buffer using this tube:
http://frank.pocnet.net/sheets/135/6/6MD8.pdf
If you look closely, you will recognize this tube as somewhat like a 12BH7 with extra plate and common cathodes.
here is the finished product:
i have decided against using a volume control after the hole has been punched.
under the hood:
6C33C SE
SE on 6C33C. At the input - SRPP at 1579 tubes, driver - 6П9 (6P9) with the screen grid control.
Output tubes mode 280 V, 180 mA.
IR volume control for each channel, on-off, mute. Manual control keys on the front panel.
The volume control made on 8 relays, step adjustment 0,5 dB.
I'd pay money for that amp. Sexy and techno. Got a schematic and where did you get it from?
6MD8 tube buffer
under the hood:
Nice !
Neurochrome.com
Joined 2009
Very nice work!! What's the chassis material?
~Tom
Hi
Is the smaller tube with the green writing from the CONN organ company. I have a bunch of them (12AU7) and I'm in Australia??
A very attractive piece IMO. And what a lovely sheen on the metal.
Is it aluminum, steel, or something else?
Disabled Account
Joined 2010
The small tube is a NOS Sylvania 7 pin 6AU6 pentode.
The chassis is a 2mm thick aluminium guitar amp chassis off eBay
Guitar Amp Chassis blank for JTM45 Marshall and others on eBay (end time 18-Jun-11 10:23:18 BST)
The chassis itself was conditioned with a bit of oil on a rag to get the sheen:)
Steve
Very nice,
Where is the grommet eh...fancy not putting a grommet in the front connection..Picky...lol
They are very nice but where is the grommet? LOL :)
M. Gregg
Here is the Super Simple Single Satge Tube preamp. The PS and amp exist on one small peice of brd with no cct. All component-2-component connections, silver soldered, plus Alps pot on the output, 4oz solid brass knob and brass arty bits. A 24V wall wart connects to the grid and this 4Ss preamp sounds better than it looks. YES REALLY!
Dynakit ST35
My 2nd build, a kit! I so do like this amplifier... it's compact and performs really well.
Now I'm planning and ordering parts for a 'completely done by myself build', a SE EL84 amplifier.
Amp #1 – SEP EL84 - Transcendar OPTs, Hammond PT and the choke.
Amp #2 – SEP EL84 - vintage Philips console PT and OPTs, Hammond choke.
Amp #3 – SEP EL84 - vintage RCA Calypso console PT and OPTs, hand-wound choke.
Amp #4 – SEP EL84 – vintage Philips EL3536 RtR PT and OPTs, Hammond choke.
Amp #5 – SEP EL84 – vintage Philips EL3536 RtR PT and OPTs, two Hammond chokes.
Why so many amps of the same kind? Well, 1) building tube amps is fun – a sort of creativity 2) it would be a shame to throw away those still-excellent transformers of yore 3) to gather money for 2A3 and (maybe) 300B and ECL86 projects (and EL84 again; they, after all, sound real nice)…
