Some more pictures
Really impressive work! Put that thing into a big glass bowl and it looks like a giant power triode ...
Hi,2.2mH - 1.6mm / 14AWG
D=80mm, L=30mm
some questions arise while looking at your stunning amp:
Were the coils treated after the wiring pls? Dipped in some kind of varnish maybe? Epoxy?
Apart from the ties to secure them in place, is it nylon wire wrapped around them?
Thanks.
Very very fine looking amp indeed
Erik
That's a nice idea. I will think about it.Really impressive work! Put that thing into a big glass bowl and it looks like a giant power triode ...
@jorgovanko
Gorgeous ! The heatsinks are from TRE-S Italy ?
No. Heatsinks are NOS Fischer SK41. I purchased them in Croatia. Here is some infos : http://www.diyaudio.com/forums/pass-labs/76428-fischer-elektonik-sk41-heatsinks.html
Erik
Thanks Erik
Yes, U are right. The coils are treated before wiring with varnish, two times. They are secured with regular nylon cable ties.
Boban
Thank you. Do you have a link of the supplier? I couldn't find this particular model on Fischer's website.Thanks
You have PM.
Well the Aleph 4 is almost finished now.
Using it with Shuntky / Pumpkin. Absolutely brilliant.
Looking good! Would you mind taking a moment and describing the sound?
- Pictures of your diy Pass amplifier
