Post your Solid State pics here
That's a 85' model alpha 230 from Hamamatsu , Japan. 23 years of block parties in the Bronx , new york , another 20 (or 30+ 100v caps everywhere) as "reborn".
I am shaking the house , PS never even gets warm. "Skived" heatsinks really put out the heat. This was good practice for the "DIY" amp's I'm about to make , they will be Soooo easy (compared to this one).
OS
just-finished μPF Amp
Dear All,
just want to share my excitement with you after finishing my μPF Amp, which stands for μ-follower+power follower.
Since the power follower which is the P version (using 2SJ162 that I had on hand) of Andrea Ciuffoli's amp has "zero" gain, so I decided to add a VAS stage built up with a 5814(ECC82) and a IRF740 in μ-follower configuration to provide a minimum gain and a pretty low output impedance to drive the power follower.
I think there is no need for any comment regarding PF sound performance, most of you are already familiar with SE Amp or PF Amp, here attached with some pictures.:D
- power off;
- stand-by mode (glowing red);
- power on (glowing blue);
- internal layout.
..... my not finished Goldmund amplifier ....:) weight ,only 11.5 kg .
Alex.
Maybe some guys will advice you to invert downwards the L-shaped alluminum adapter, so to better dissipate heat through the large heatsink.
very definitely.
There are two advanatges to inverting the L angle.
1.) the heat transfer interface is moved down towards the optimum height for heat dissipation (~ 40% up from the bottom)
2.) The output devices can be mounted much closer to the heatsink, significantly reducing the thermal resistance of the thin horizontal leg of the L.
There is a small advantage to mounting the To3s on the outside of the L. The inside face will be non-flat and extremely difficult to be corrected to flat. The outside face of the L is also likely to be non-flat but these faces can much more easily be corrected to flat, or at least flat enough.
Here's my Borbely 894/211 Clone.
and my Pumpkin / Shuntky
all being built to compliment what will be a DIY-PASS F4
Andy
Might as well throw the pictures in here as well.
This is my first prototype of a headphone amp, only one channel atm. Still learning the ropes of solid state. Amp does work fine after all the kinks were worked out.
Running only 2n3904/2n3906 and MJE3055/MJE2955. Will try other alternatives in the next version.
Kolbjørn
