100W Ultimate Fidelity Amplifier
Try to set 0,5V-1V on 10R, with 2V bias will be 200mA, it's to high. Start with 50mA (0,5V on 10R), and check heatsink temperature after 10min.
I've adjust bias 50mA and it works now....very2 clear sound....:cheers:
I use 32VAC supply........heatsink temperature is normal.......
What is the minimun load impedance for AX-14??
How to get more bass???
Hi everybody, i just analysed Ax14 circuit with SPICE simulator. everything is ok upto
pre- drivers. voltage at base of driver Q11 shows -1.25 V but base of Q13 shows only
+ 0.680V. i am expecting help from apex and other experts. kindly reply. (sorry for bad
english)
english)
Help you to build this amplifier or help you to simulate this amplifier, can you post pictures or files from SPICE simulator?
