Mic, Line, EQ... Preamps
BJT Pre Amp
Is this correct Sir?
Use J309, J310... 2SK246 different pins, amp can work without 'mute' fet,
Miles,
I have already tried using 2SK246(pins rotated). Firing up there is no mute on or off.
I still hear thumb. I have taken off the FET.
Now the amp itself works but signal input at preamp side, I have no gain. With volume at full opened, I hear very low noise.
Therefore connected to amp input with 50K pot at C14, the amp works good.
Very good bass.
Please tell me what to check at the preamp side.
Raj
Miles,
Very good bass.
Raj
Can you post pictures?
Connect from base of outputs BC550 to colector of inputs BC560 missing !
You can use this preamp with any amp.
Preamp can work with +/-12V minimum with 18k instead 33k, but use +/-24V.
Mr. mile, Can I get a schematic/ layout for your tone control subwoofer/ x over / good active low pass and high pass filter for my Power amp H900 and my speaker???
PLease.
Thanx you for your schematic H900. It's very very great...
I love apex...
