Thinking of upgrading these Caps on the PSU - are the ones above any good or should I spend more - not going to use the analogue RCA ouputs only the digital into external DAC?
Also the servo clock - should I upgrade this on its own or use the clock signal from the newly installed Audiocom Superclock with a divide by 2 circuit?
Cheers
You can get better but then you're getting to 3 times the price. For about £10 per cap, you can use audio upgrades SI caps. They are also 22,000uF but are even lower ESR. I have about 12 of them in my player now It's def worth it if you're looking push the player even further!!
Barry,
How much for the CD63 remote - when I pruchased mine from ebay it didnt have a remote
Cheers
Send me your address and i'll post it to you. No money required.
There is talk...http://www.national.com/ds/LM/LME49990.pdf
Anyone know about this or if it is applicable to our story?
Ordered 4 off the samples program 8 usd postage have to make a couple of daughter boards see how they compare to lm4562s.I actually have some on order as samples to test
Brent
cheers alan
Were you a human cannonball?
Brent
Brent
Hard wiring usually gets rid of all these problems. Bad gnd etc on the ribbon cause no end of reading & tracking errors. Also check R107 for 5V, sometimes this res goes a little high dropping the V after it too much + check the rubber mounts the traverse sits on as these can split and cause the traverse to sit slightly off.
Brent
Brent
- Digital Source
- Marantz CD63 & CD67 mods list
