Marantz CD63 & CD67 mods list
try these points for connection. They are the same as the pins of the regulator itself but much easier to get too.
I have since blown the decoder in my Arcam Alpha (a ground wire lifted overnight forcing unregulated voltage onto the output of a regulator) but I soldered in a new SMD SAA7310 and it worked fine after that. Not bad considering the EPIC mods list on that player.
LOL those ground wires are such a pain, the way they just 'lift overnight'.
Brent
Brent
I will say only this: if you use random bits of old tinned wire (e.g. from a pc smps) it's a case of how often will solder joints break, not will they. I learnt this the hard way and now only use bits of Kimber speaker wire as the quality is such you almost always get a great, solid joint.
Good general advice for anyone doing their first PSU mods.
