900W H-class PA Amp with Limiter
Use 1k2/2W instead 2k2/2W from MV to 15V zeners, and you can use 2R load with this rail.
If you refer to the resistor at 3.3K /1 W in post #116, that sounds ok, only for setting the correct bias current into the zener. Otherwise please tell me whis is the last/correct schematic.
Anyway, thanks a lot !:D:D:D
Your schematic is GREAT and I am going to use the output stage connected to something like a LME49810 as a VAS to make a sturdy rugged PA!
effebi
effebi
You can use separate +/-15V PSU (from protect board) and drop out resistors and zeners, in that case no need to set bias current for zeners with different rail voltages.
BR = AC X 1.4 at 100% efficiency not X 1.5....
Silver,
A transformer does not give out a fixed voltage.
The secondary Vac depends on the mains supply voltage (primary Vac) and on the load current Iac.
The DC voltage from the PSU is not a fixed value, it wanders all over the place.
We can measure the worst case highest zero current PSU voltage. We and you will now know what the highest DC voltage you can ever get from the PSU.
Work down from that highest to find typical DC voltages.
hi apex,
i tried your darlington topology.and guess what everything was ok no abnormal
readings.no sagging of voltages. dc offset of 2mv.same reading on every collector.
then i switched back to normal driver stage with mje15032/33 .switched on
2.1mv dc offset.no voltage sagging everything normal.then i saw i forget to add
22ohm resistor which was connected to both emmiters of mje15032/33.as i
connect then every thing messes up.30 mv dc offset.voltages sags 60 to 38
and-60 to-14.different reading on every collector.what should i do.
thanks
ravs
be a vegeterian.....
6th H900
ready for mounting 6th 2 channel H900
Thanx to Miles
