Oh, it's not that off topic. PSRR on the UcD 180HG and 400HG is only 65dB and isn't speced as a function of frequency. So, depending on the shape of the curve, it's potentially quite low by 20kHz---though based on the THD behavior I'd guess it's probably fairly flat. Not bad by class D standards but I'd still expect performance to be fairly sensitive to the supply. Presumably Hypex developed the HxRs for a reason. ![Stick out tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Looks like PSU2 uses only a basic trafo model, unfortunately.
Yeah. Recent example here.So what you do is actually kind a RF layout with caps additionally (?) shorting to a ground plane?
I used the ucd180 because they have good specs and are cheapest in the range and I improved the opamp.
As long I do not under stand why a hrx shout be better.
My amp is build of spare birch multiplex pieces and other stuff that laid around. Next step I am working on build in a 24bit DAC.
![194084d1288288001-hi-end-hi-efficency-loudspeakers-horn-onken-dsc00680.jpg](https://www.diyaudio.com/forums/attachments/multi-way/194084d1288288001-hi-end-hi-efficency-loudspeakers-horn-onken-dsc00680.jpg)
Those HxR regulators lower the PSU noise for the OP-amp and possibly other parts of the circuit I guess... can't be bad, so I thought "what the heck... lets have them too". Anyway, those regulators are not all that expensive.
No problems with the UcD modules getting too hot there Helmuth?
No I mounted them to black a headsink from about 3 degrees/W.
two modules of 180 =360W X 8% losses =28,8W
3X28,8 =86,4 degrees rise with a ambient of 30 degrees 116,4 degrees.
But it isn't real to estimate that a stereo amp constant has to output 360W.
My occupation is electronics and one thing I do very often is temperature testing of switching lamp drivers we design from 50W to 40000W. This for UL approval and endurance testing.
You hardly will maintain that 3deg/w of the bare heat sink in the wooden enclosure you've built - but I agree - it might not need that much more than idle current dissipation - usually
Michael
I think by feeling it it will be 40-50 degrees. And I know how it feels. When you look good you see the sides are also aluminum. And the connection box is also aluminum. In-fact not all power will be direct radiated to the heat-sink on the circuit board so even with 8W loss not al the loss will end up on the heatsink. And I use a perforated alu plate at bottom and top to have good air flow.You hardly will maintain that 3deg/w of the bare heat sink in the wooden enclosure you've built - but I agree - it might not need that much more than idle current dissipation - usually
Michael
Infact I didn't calculate at all when building it I knew it would be enough.
And a wooden enclosure does ensure a real warmth audiofeel sound.
Yeah - how could it be any different, with the components being prevented from any cold
Michael
Michael
Never use hardwood, harsh sound.
LOLAnd a wooden enclosure does ensure a real warmth audiofeel sound.
What type of wood sounds best ?
I like the amp, very nice. In fact it's given me an idea
David
As I advised birch ply wood one of the best woods for audio.LOL
What type of wood sounds best ?![]()
Best sound you get when you also strip your capacitors and place a wooden exterior.
![whacko :whacko: :whacko:](https://files.diyaudio.com/forums/images/smilies/crazy.gif)
![KeesOLafHoutplusElna.jpg](https://www.dhtrob.com/keesolaf/afbeeldingen/KeesOLafHoutplusElna.jpg)
|| DHTRob - Kees & Olaf: Een electrolytische condensator verbouwd...||
Great - one would not believe what people get interested in - thanks for that link
The English version:
|| DHTRob - Projects: Rebuilding a capacitor (1).. ||
So there is some room for improvement with your multiplex housings - taking tropical woods![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
(no good for the environment though !)
Stig Erik - you really have to adapt your old "life is too short..." for this
Michael
Michael
without yokes wood is still a nice insulating material to work with mine was 16euro for paint and aluminium plate.
And look now like this.
you see no difference.
This also goos for the sound its makes and it makes DIY fun again. Fast to build great result and 600euro saved.
Metal is cheap to produce with for a manufaturer. I Like wood and do see a real advantage in the reduce unwanted parasitic capacitors in the amp.
![Yamaha.jpg](https://i23.photobucket.com/albums/b384/fiebke/Yamaha.jpg)
![205123d1294859102-hypex-ucd180hg-hxr-400hg-hxr-schermafbeelding-2011-01-12-om-20.02.25.jpg](https://www.diyaudio.com/forums/attachments/class-d/205123d1294859102-hypex-ucd180hg-hxr-400hg-hxr-schermafbeelding-2011-01-12-om-20.02.25.jpg)
Here is a link that shows that Icepower modules can come in an good looking cabinet and at a good price. Link
It contains 2 icepower 125 ASX2 modules for the price of 4000dkk (535euro). a four channel amp at that pricepoint is hard to beat in my mind
In black (what i would choose)
In white
In white
Mine has a 24 step attenuator speaker h-a-h-b-h-ab (h=head phone, a=output a,b=output b) switch and 6 inputs a 24 bit dacHere is a link that shows that Icepower modules can come in an good looking cabinet and at a good price. Link
- Class D
- Hypex UcD180HG HxR or 400HG HxR ?
