Salas hotrodded blue DCB1 build
I have my board almost finished. I just need to desolder one part which is the wrong value and then I can begin testing my work. As I'm new to diy I would certainly appreciate it if someone could answer the following questions.
1) Are the TO-247 heat sinks in the v1.0.4 bom adequate for 200mA current? If not can someone provide a link to a heat sink I can order.
2) I am currently using Uriah's Lighter Note LDR kit and would like to use it as the volume control for the dcb1. Should I be going source->dcb1->lighter note->amp? Or should the lighter note be before the dcb1?
3) Also, I have two sources--digital and vinyl. What would be the best solution with my configuration if I need two inputs?
I apologize in advance if these questions have been answered before. I searched through this thread repeatedly without finding answers to my questions.
Joined 2006
Knassari- On 3, I uses a DPDT type switch. It's cooler looking than a knob IMO. :)
Additionally, I think Oliver used a third party relay PCB to integrate with the Hot Rod hypnotize.
I can also send you some medium size CPU heatsinks for cost of shipping if you know how to use a tap,
you can use thermal epoxy and glue them to copper or aluminum. That's what I did.
Great, thanks.
Did you drill out the chassis yourself?
I did yes, just using a bosh hand drill. Very easy to drill as I bought the case with 3mm front panel for now. I intend to have some nice custom 10mm panels made by Schaeffer AG one day.
The large holes for switch, power inlet and RCA sockets were cut using metal hole cutters like this:
BOSCH|2608580402|HOLESAW, HSS, BI-METAL, 22MM | Farnell United Kingdom
http://uk.farnell.com/ruko/106-201/arbor-holder-with-pilot-drill-type/dp/379128
George, who designed the Lightspeed, recommends that the Lightspeed be last in the chain feeding the Power Amplifier.
He says it gives better sound this way.
However, due to the high output impedance of the LDR combination, the passive volume control must be connected with very short cables, or none at all and the RF attenuation cap inside the Power Amplifier must be scaled to suit the source output impedance.
using source > DCB1 > long cables > LDR/Power Amp allows the lowish output impedance of the DCB1 to drive the cables and the LDR/Power Amplifier to be designed as a compatible pair.
The alternative, is to use long cables to the power amplifier and use the DCB1 to drive these cables.
This would result in the LDR/DCB1 being designed as the compatible pair.
source > LDR/DCB1 > long cables > Power Amplifier.
Choose which suits your location of equipment and skills to design the appropriate combo.
A further (expensive) alternative is:
source/DCB1 > long cables > LDR/DCB1 > long cables > Power Amplifier.
This uses the lowish output impedance of the DCB1 to drive all the cables in the system.
And finally:
source>LDR>Power Amplifier where each side of the transmit/receive pair is designed to be compatible.
Yeah, I could have sworn I read in the lightspeed thread that the optical control is placed just before the power amp. I admit I tried it, worked first time, sounded good so I left it. I'm intrigued by Salas' suggestion and will give it a go just out of interest.
I'm running the Legato SE which technically means that I have a buffer feeding into another buffer, Whether this is a good thing I don't know. I'll ask the guys on the lightspeed thread and see what they suggest.
Andrew - when you say the RF attenuation cap, do you mean the input cap? I have a dual mono amp using Avondale NCC200 boards which are based on the Naim RCA circuit.
Cheers
RUKO|106 201|ARBOR HOLDER WITH PILOT DRILL | Farnell United Kingdom
Is that a 2u or 3u case?
I'm looking at a 2u, and the larger caps just fit in the case (it would leave about 10mm room up top).
Oh, one other thing, I thought the 3mm front panels had holes in them for rack mounting?
I'm looking at 2x of 1PS02PN these for my blue dcb1 buffer.
Thanks,
JG
