do you like the play on words?
Got an old console today. Now my normal approach has been to gut the things completely, pull the usable tubes, remove tx's and throw away the rest.
But this week at work I've felt the need for a little desktop amp that glows. So this ECL82 SE item looks like an ideal candidate for rebirth.
Currently it has MW and SW in the tuner section. That will all go - I have a good Technics tuner that will plug in to provide that side.
Inputs will be needed for the computer and maybe (later on) an i-pod dock.
The chassis will stay as it is (although I may clean it!!). Obviously it needs a full re-capping, and I'll probably LED bias the triode sections and LM3x7 bias the pentodes. The cute-sy opt's are 4ohm output, so lots of speaker options to consider too...
I'm thinking a nice oiled timber box with a mesh grill front and rear - a cross between a Tivoli radio and a Marshall amp.
Anything I've missed considering?
Looks like a fun project.
Those heavy tuner flywheels (sans the big pulley) add a really classy 'feel' to a stepped attenuator. I used one as front panel bearing/shaft, so I could mount the attenuator at the inside/back near the input circuit, with an extension shaft rigged between the 2. Worked beautifully with a big volume knob.
..Todd
..Todd
Nice find! As for the play on words, I finally got it after a minute or so. They say the mind's the first thing to go...
I have a thing for old console amps too. I'm not sure if it's because they appeal to my urge for instant gratification, or because playing with one takes me back to my youth (I "restored" - read butchered - lots of old tube gear as a kid).
Here in the states the old Magnavox stuff in particular is nice, mainly since the amps are usually separate from the tuner/phono sections.
I've recently run across an old Telefunken Delmonico console that's beyond restoration. I was hoping for a pair of EL84's under the hood, but alas - it's a pair o' 6GW8's...
Hi Mr Z. You are lucky - over here consoles (in fact everything) was local manufacture and almost invariably low power SE output. Its very rare to find a pp design except for a couple of later stand-alone hifi amps (the Fountain Gem series) that were pp using ecl and el series tubes in the finals.
There are occasional Philips Hi-Z units turning up but almost no north american stuff since our voltages are so different (we are 230VAC)
...but almost no north american stuff since our voltages are so different (we are 230VAC)
From the picture, it could be any number of console amps i've pulled. I've pulled all sorts of OPTs that are cosmetically interchangable.
dave
On some consoles the B+ went into a tap partway in from the end. The longer end went to the plate and the shorter to the screen. The idea was for the residual hum in the PS to be cancelled in the OPT. Don't know if you could swap connections for UL or not.
e.g.
I suppose you could check by disconnecting and measuring DCR from each tap to the others.
e.g.
On some consoles the B+ went into a tap partway in from the end.... I suppose you could check by disconnecting and measuring DCR from each tap to the others.
Thanks Mike - I haven't seen one like that down here but I will check it out - cheers!
Hate to tell you guys, but its a bright clear sunny day, we are looking to get to around 28 degrees C. I don't think the amp is going to see much movement today...
- Tubes / Valves
- fee-nix, the desktop amp
