F5 power amplifier
That will be done when I get the other channel done :D The first one sounds amazing! At the moment at 1.3 bias, offset is 10mv but I have not tune it yet at full operating temp.
I am asking about the technical measurable differences by reducing the bias. Not all of us are lucky enough to have access to good analizing equipment :)
Best regards,
Regi
Well Regi,
Here's a less technical one for you - the power fets do sound better when the sinks are operating hotter than 50*C (assuming good fet -> sink transfer) so reducing current will reduce fet temp that will reduce sink temp that will change the sound.
So you can keep the temp up (test by finger!) when reducing the current by using smaller heatsink, blocking some of the fins, or hacking off a few cms!
There is a lower power variation in the thread awhile back, for the same purpose that you want - perhaps someone knows the post number?
Well Regi,
Thanks James, but what I am trying to fix is just that, I think my heatsink is too hot. I am waiting to receive in 3 weeks a digital IR thermometer to check it. So if I am not using most of the power, lowering bias should reduce temp.
Regi
Official Court Jester
Joined 2003
Best regards,
Regi
If you only listen at 1 watt then the difference will be minor. I could show you some simulated results, but in the end all that matters is how it sounds while your listening to your favourite album. So that is why I suggested adjusting the bias and listening.
If you really want to see simulations, I will do it though.
That would be very interesting if you have them handy (the simulations) :)
Thank you, now it is clearer. I will put some pictures as soon as I assemble it, I kinda like it :D
I'm going to drill the holes for the enclosure and heatsinks. At first, I wasn't sure a 6-32 screw was sufficient for the output devices because I didn't want to break off a small screw while trying to get good contact with the heatsink. Now I just noticed a 6-32 screw won't fit through the hole in the Fairchild outputs. I guess I'll have to use smaller screws. Does someone know what size screws to use here?
I mentioned this to NP about a year ago! I just put them in the drill press. You can always get a metric to fit.
You put the output devices in the drill press?
Seems like it's tight on the back side. The screw goes almost all the way through and gets stuck. I tried reaming a little on the back and can get it through but I don't want to compromise the integrity of the transistor case. I'm afraid it will crack from the heat.
The data sheet says the hole is 3.6 + or - .10 . I guess it's in millimeters. So whatever the closest metric size is.
