Arjen Helder's 2050 boards
Here are some photos of the top and underside of the board. Had a hard time getting to focus on small components for the top view.
Thanks chlorofille, I've just compared your pictures with my boards, and they are the same. In my boards there is nothing you could may think that is burned. They are new as they came.
May be I can get them "refurbished" from Arjen. He is being very helpfull with all this. Also all of you you are very kind, THANKS.
I'll keep to update to what is happening.
Bye
With help from Arjen, I got my 2050 boards up and running again. I'm extremely pleased with the sound quality and the construction quality. There's much more room on the board for modifications, should you go that way and the boards made from better material.
The overall sound is relaxed but detailed. It's a marked improvement over the SURE board (which is very good, especially for the price) and the 2020.
2x3 channel 2050
Here is my shot with the Helder's 2050 boards. I have just finished one of two 3 channel amp. I have used one regulated power supply with 160VA toroid for each board. Regulated at 27V. No noise or hum at all. Very happy with the sound. Chassi from HiFI2000
Well I finally got the time to wire up Arjens boards. I'm using some Jupiter cloth covered solid core wire for signal with Vampire input jacks. The speaker posts are Cardas. I'm trying a lithium battery pack with a three step charger. I replaced the stock input caps with cascaded Sonicaps. The first hi res file of Boz Scaggs' "Dig" sounds mighty fine, if it improves with burn in I'll be in sonic nirvana...
mmhh, i forgot about 41hz, i thought that arjen's amp were a little bit better.
i suspect you advice the amp 4 as better equivalent of the arjen ?
i wonder if the 41hz need any tweaks: that said i mean, the arjen and sure have an enormous amount of tweaks, maybe the 41hz doesn't need them.
thanks
