naah ..... that was in humoristic part of forum ....
there is still no SM for A J
read all other SMs of any Aleph and talk is the same ; difference is subtle - few tiny jfets in input stage , instead of welding capable mosfets .
there is one file - myriad times posted by me - Aleph 30 pdf , made by Algar_emi ; almost every part is marked and commented
that small file is more informative than any Aleph SM , from many reasons - first one is that Papa didn't wrote SM for usual Greedy Boy , but for skilled tech .
Algar_emi made this file for usual Greedy Boy
Thanks. That should do.
@anil, there is builder in Mumbai who's built both amps, the Aleph is sweeter sounding and runs hotter, the F5 has more sparkle and tingle. The weather here is perfect for the Aleph if the sound signature is to your taste. You will need big sinks, plus the Aleph has more devices IIRC.
I belive this could be the right schm. ?
http://www.diyaudio.com/forums/attachment.php?postid=1343785&stamp=1194303063
... Hehe ZM... I got it
Jesper
EDIT : Found this http://www.diyaudio.com/forums/pass-labs/111197-aleph-j-schematic-7.html
Jesper
would love to have a listen to the F5 if he/she is up for it...
Where in india do you live Sangram?
I'm pretty sure he won't have any issues - though I'm not sure if he's a member here. PM me your cellphone number and I'll set it up for you. I'm currently in Bangalore, and am relocating to Gurgaon in December.
naah ..........
Thanks. I need to look around for 2sj109s...
Yep's ...
I am having problems, reading the schm.
I can't figure out, where G, D and S goes on 2SJ109 - Q1A/Q1B ?
"G toward R1, R4; D Q2's C; S ....... "
hmmm... sry. for my "bad" quistion before.. i have been reading the Aleph30 manuel/schm. and i really think you are wrong here !
G = toward R1 and R4 is right!
S = against ztx550 Q2
D = Against R7
Or
Jesper
EDIT : http://en.wikipedia.org/wiki/File:JFET_P-dep_symbol.svg
D = Against R7
Or
Jesper
D = Against R7
Or
Jesper
DOH!
(you're right! My memory is bad)
I must have missed some posts in this thread because I really expected to see some response's like; B4/B5, F6, AlephJ J, SOZ-J, BOZ-J BOSOZ-J something??? Maybe even a ZV4-J???
Do I hear feathers rustling?
I suppose we should have asked how many amps he intends on building. If this is going to be his last amp build I am not sure I would recommend Aleph J. On the other hand if he is like me and is planning on building 7 amps or so, then I think Aleph J/30 is probably not a bad suggestion, at all.
When I set out to make F5, I thought that this was my last amp and then I made my F5. Like Papa said somewhere, if you make one, you will end up making others as well. Again, i believe that if I make Aleph J, that would be my last amp. Don't know what happens after the build.
Thanks for all the inputs.
Cheers.
- Next suggested build after F5
