500W PA amplifier with Limiter
andrewlebon,
but i think it's not right to feed pos.12v to pin 4,
and neg.12v to pin 8
hi engel dela pena
greetings yes its tested working on real 1000 watt speakers
1 tlo 72 step driver ic gets supply from 15 volt zeners on b500 pcb
2 i use IRF2807 MOSFETS GET WARM MY HEAT SINK IS THICK SO make heat
sink thicker
3 check amp with tlo72 step regulator with 100 WATT BULB IN SERIES
thanking you
andrew lebon
tlo
hi engel dela pena
sink thicker
thanking you
andrew lebon
andrewlebon
one last thing mate.
w/c of this two is your pin 1?
Disabled Account
Joined 2009
mamak,
b500 supply is 40-0-40ac
torroid,
i bought it from a surplus shop w/o coil,
and recoil it,
only using locally made speaker,but sound is clear amp is clean,many builder already testify
i want to try build this amp and want drive pioneer car subwoofer.this amp enough to drive about 400watt amps?and my problem is build car smps.u have any circuit high power smps?
