I'm thinking about building a Burr-Brown based DAC very similar to the one I built with the CS4398 that I showed in this thread a while ago. It would use the same power supply sections, and also use a pair of Lundahl transformers. In fact it will look almost identical, but use a DIR9001, SRC4192, and a PCM1794. I figure that is the closest comparison I can make. I'll be using LL1674 transformers instead of the LL1690's that I used for the CS4398 DAC chip.
Sheldon
Sheldon
Don't forget ,some top DAC use PCM 1794: Ayon,Audiomat Maestro Reference ., Yamamoto and certainly some others(please mame it if you know). Was able to listen crazyfrog chinese DAC with PCM1798 in my own system and believe me my 2000$DAC was not in the game at all. PCM 1794/98 is the way to go for cheap($) and top notch DAC
Yes I will and hope that others that does this does the same.You must keep us informed of your progress. I would love to see a direct comparison between the 4398 and a current out chip. From what I have read, getting the I/V conversion right with trafos is very difficult and time consuming. I'm sure you have made a good decision by trusting the trafo manufacturer's recommendations. Compared to them we are all just a bunch of hackers.
I assume that when not using the opamps that´s under the adapter board I have to solder a lead from input to output of the opamp,is there any pictures of this,I could find out from the schema but pics would be nice..
I assume that when not using the opamps that´s under the adapter board I have to solder a lead from input to output of the opamp,is there any pictures of this,I could find out from the schema but pics would be nice..![]()
Isn't that picture:
![181363d1279897837-experience-diy-dac-daughter-pcb.jpg](https://www.diyaudio.com/forums/attachments/digital-line-level/181363d1279897837-experience-diy-dac-daughter-pcb.jpg)
Theres nothing wrong with that pic.Isn't that picture:clear enaugh?![]()
Just that I thought that those points (L+R+ ect)where after the opamp,now I see they are Before the opamp...
What trafos were used?
Would the LL1674 be a good choice for the PCM1798?
upsampling
Hello Guys,
I was told that the upsampling module is only able to upsample to 96KHz on the SPDIF input while it upsample up to 192Khz on the USB... is that correct? Why?
If yes, what happens if my audio card output 96KHz on the SPDIF and the upsample module is in?
Keph
Hello Guys,
Keph
Would this be worth adding to clean up the power to the DAC.
some of the plastic on my power inlet broke - still works, but I need to get a replacement.
Thanks!
OKAYA 6 Amp 250V AC Power IEC Inlet EMI Noise Filter - eBay (item 400140559985 end time Jul-31-10 20:18:02 PDT)
Thanks!
I was using one of these , with switch and fuse, for a while. Then someone on this forum mentioned that EMI filters made the DAC sound harsh so of course I immediately replaced it with a switchless, fuseless, filterless connector.
Did I hear a difference? Uh I'm not sure.
I have used a filter in damned near everything I have ever built, it's my SOP, and I have built a lot of gear. I would like to hear an explanation as to how EMI can make a piece of gear sound better. Maybe the filters confuse the electrons, those critters aren't very smart.
Definitely give the filter a go. They do reduce RFI, but they can also distort the mains waveform due to the undefined impedance of the mains, so for audio purposes they may do more harm than good.
If you are interested in technobabble, take a look here ....
Acoustica
There's a section on mains issues with some interesting info.
Acoustica
Acoustica
What a nice web site. Interesting, lot of good things.
![spin :spin: :spin:](https://files.diyaudio.com/forums/images/smilies/spin.gif)
Now that I went and removed it I would like an explanation as to how an EMI filter was supposed to make my DAC sound worse.
![Deer :deer: :deer:](https://files.diyaudio.com/forums/images/smilies/deer.gif)
Acoustica
After reading all the stuff on mains problems I have concluded that all my gear is crap and I'm selling everything and buying an Ipod and some ear buds.
Thanks for the explanation and link.
Usually I prefer skipping the technobabble but I'll take a look anyway.
It's hard to A/B this as by the time I've disconnected/connected everything my aging ears have pretty much forgotten the subtle(if any) differences.
Now that I went and removed it I would like an explanation as to how an EMI filter was supposed to make my DAC sound worse.![]()
It should not, particularly if you have well designed power supplies and regulation stages. In fact it will make your equipment less prone to being upset by other bad apples on the same powerline. Remember, many people pay thousands of dollars for the same corcom filter in a fancy box with outlets.
Measurements will set you free, if you make changes without the ability to see what you've done, you are wondering around in the dark. Everything you hear is directly related to a measurement, which measurement and how to correlate the measurements to what you hear is the art in this.
- Digital Line Level
- Experience with this DIY DAC ?
