500W PA amplifier with Limiter
Sorry, if I insult you in some way. Your amp is different and better in every way.
I meant visually by dimensions, part places and parts I use... not by how it works.
As you said to me ''My PA200 is very similar like old project PA300 with MJE15003".
But thanks for explaining to me how P200 works.
I share B500 with all forum members, now that is our amp. Thank you for build B500 and post pictures. I expect more amps in future use this topology.
Apex..this my picture B500 after add fan, so 2 fan (sorry can't see that picture) and adding capasitor 0,22 uf/630v (yellow) + Resistor 17K/2w paralel with capasitor bank in PSU and softstart in AC in. With adding this, how effect for B500?
Pozdrav,
Pozdrav,
I expect many upgrades in a future, and you share your expiriance with us. This upgrades you did is OK. Thank you for building and post pictures.
Pozdrav
I meant to decrease voltage +/-80V with resistors,zener diode and power transistors.
This is posible, but you have high disipation and must use large heatsinks for transistor, and if you have demage of transistor, there will be +/-80V on protect and this cause lot of demage. Simple and not expensive solution is to use extra 2x18v smal transformer,
Hi Apex,
confirm: how to applied NSL-32 on PCB B500? NSL-32 just arrived from my friends in Singapore. In your PCB B500, drawing NSL-32 with "dot" is it match with "dot" on body NSL-32?? This ilustration:
Sorry, stupid question...:confused:
Dot is katode of LED inside NSL32, resistor is on oposite side,
Hi, Apex. :)
What do you think about this amplifier?
Have you build something like this?
Schematics.
I resized this picture because it's to big,if you want better resolution I will send you by mail.
regards
