500W PA amplifier with Limiter
B500
Hi,Apex.
I had discovered why my B500 little buzz on speakers when there is no music. My computer is generating that sound. When I disconnect cinc, it stops. :)
Can amplifier work with 2SB817/2SD1047, BD249/BD250 transistors without changing anything, with lower voltage? I have some supplies of those transistors. :D
Hi,Apex.
See post #40, and in thread http://www.diyaudio.com/forums/solid-state/164630-50w-mosfet-amplifier-irf540-irf9540-3.html you can also see post #23. Can you post some pictures? What speakers you use, and how its sound with B500 compareing with another amps?
B500 is stronger then most amplifiers I had build before.
Great sound on hifi speakers, used Pioneer and EI Nis for Hi-fi test.
And Eminence Kappa 18" and Delta 12" LF for PA test.
Will post pictures in a few days.
I had look you posts, this amplifier is just like B500 but with 2SB817/2SD1047 transistors and 2K2/5W resistors. Are there any change in pcb?
You can use B500 pcb for B250,
And pcb of Apex 120 with BDE83/84.
One of my technics of making PCB: :)
1.print PCB on paper
2.Use iron to transfer print(lines) on PCB
3.put pcb with paper in cold water
