Mic, Line, EQ... Preamps
apex,
like this set up
ben duncan book cover
amplifier stockfile
is this parallel set up,sharing one signal ?
summing?
how to implement multiple amp set up?
apex,
sorry for so many questions
i checked crown i.t4000/8000 manual
and found that it has provided another xlr connectors the signal at these connector is paralleled with the input signal for feeding the signal to another amplifiers
can i use post #73 and add another XLR connector for feeding the signal to another amps?
regards
apex,
regards
Yes with balanced input/buffer (post #73) you can use any amp you want in paralel connectin,
Single pre out to multiple ampa
Active four way x-over have separate outputs for sub, mid-bass, midle and horn amplifiers, like Mackie 'fussion' system,
Hi, some or even most of the pro amps this day have link out male XLR balanced out to daizy chain multiple amplifiers.
Apex had also posted a balanced input pre amp with link out XLR port, that would I think fit your requirement.
Thanks, good luck:
>Joel
Philippines
