I have not pcb for stereo three way tone control, but you can do it yourself with using ML3 schematics, this tone control is advantage compare with other schematics becouse adjusting mid range have no efect to high range, it's not case with others schematics.or a stereo tone control with just bass, mid and treble?
You can add ML3 in any Hi-Fi amp on 'aux' input, and use for 'karaoke party',Hi apexaudi.
Thank you for share schematic & pcb.
I use for Home entertainment.
Regards.
i just paste it,maskin tape at the bottomHi engel,
Little interested with your pcb on the crt monitor. How could i transfer image from paper to pcb for eching? draw or is there any easy way? need help. thanks
pinted design over it
In this thread I will post preamps, EQ, active x-overs, VU...
sir...
do you have an audio distributor???...would it be okey for you to post it here???...for ready made audio distributors are hard to find in our locality...
tnx en regards...
What did you mean 'audio distributor', for what purpose you need to use this circuit?sir...
tnx en regards...
a circuit that has 1 line input/2 for stereo with 2, 4,6 or more output with the same gain as the input...so i can use more amps using 1 signal input...
Any circuit with OP amp in output stage have low output impedanse, and you can use more amps in parallel connect.a circuit that has 1 line input/2 for stereo with 2, 4,6 or more output with the same gain as the input...so i can use more amps using 1 signal input...
sir...,,
how do i do that???...
coz in our place, we use audio distributors to use more amps...like in discos...
You can use this circuit with GND lift switch,Hi apex plz help me for balanced pre amp pcb
Do you want to have balanced output circuit for each channel?sir...,,
if it helps then i'd say yes pls...
sir...
how does this crkt differ with this one???...
All PA amps have similar balanced input, and you can use any of them.sir...
apex,
distribution amp
this is the way how i understand eesiboy
in like manner,this is how many commercial mixer does, it is the sub outs
where we can assign more amp in the same or different application
sub
mid hi
monitor
this is a good question
hope to hear you soon
regards
distribution amp
sub
mid hi
monitor
regards
- Live Sound
- PA Systems
- Mic, Line, EQ... Preamps
