F5 with 2SK2013/2SJ313
Official Court Jester
Joined 2003
Have you also tried IRF9610/610?
I actually had the same idea as yourself a while ago, but it is often hard to find the time, especially when you have too many ideas.
Great work, these sought of reports are a great contribution. It will definitely motivate me to try it out
tried tested abused :rofl:
they're simply not up to task , comparing to these ones
Joined 2003
Yes, long time ago - their inherent non-linearity makes them usable only as a CCS or as a voltage regulators, maybe cascoding devices.
IME, those are sub-optimal parts to use as amplifying devices in audio - maybe in guitar amps or in PA amps or in designs with a lot of NFB...
luckily , I'm not an emg .... ing... img.... wtf! not even good at math :rofl:
:cheers:
(now - you'll say that toobz aren't good for audio :clown: )
I thought low gain was preferable for HP amps, with a standard 2V in out its pretty loud. Besides I crank it up full all of the time so best to keep gain low;)
Would changeing the bias voltage be a simple adustment of the pot and maybe adjacent resitor that sets the Vref of the TL431?
Well IRF9610 is used in the front end of Aleph 3/30 etc, so they can't be too bad.
But I take your point, the toshiba devices are much more linear according to the data sheets.
Maybe I should also try the toshibas in the front end of my Aleph 30.
I also like the look of 2sj407, not sure if there is a complementary N channel version though.
How about using these on the burning amps 1 and 2 to replace irf610.
Do they really need to be biased high? How about 50mA or 100mA
I understand you want to bias them high on the F5 output stage, but do you really need to bias them that high in a circuit such as BA2.
The other option is to throw a power Jfet in that position, however that is an expensive option.
Joined 2005
Hard-wired the thing during the past weekend. I picked what I thought a rather generous sized heatsink so I could play with high current bias. And hopefully build a balanced version with these sinks. :)
Joined 2005
To follow up my attempt to try this a line amp...
I supplied each channel with a set Jung's super regulator set at +/-23V as seem the attached picture. I've been listening to the line amp for a week now. This version of F5 with a pair of k2013/j313 indeed makes a very good lineamp.
I tried varying the bias of the output Mosfets up to 450mA where the regulators seemed running out of steam(the heatsink for the pass devices became very hot). It did sound better at higher bias but the dc drift at the output was getting bigger too. I settled at 250mA where it sounded good and the dc stability was good too.
This circuit should make a very good sounding headphone amp too.
Anything I can do to minimize the dc drift at higher bias?
Joined 2009
I tried the other option and put two SSR100 instead of irf610
......sounds more liquid!:cheers:
