No, if you want use two single OP instead one dual, use two TL071 instead one TL072,apex, can i use 741 op-amp instead of TL072?
coz i'll try to incorporate step-driver using an op-amp and the main amp on a
single pcb
mane go alexan if you go to manilathank you so much...
mje's are nowhere to be found in our city... thats why i settled on using TIP's
but still thinking of H900.... hope Engel de la Pena would tell me where to find MJE's..
i'm located at Iloilo City, an hour of plane flight to Manila
i'm afraid we cannot build h900
but instead build b500 with tlo72 step driver all parts available
regards
oh sorry... i mean two 741's, got 6pcs. of it and thought i can use it instead of tl071.
regards
hi engel....ang layo naman...neway ask kung anu mabuti i replace sa mje's?
741 can't be used, use TL071 it's not expensive.oh sorry... i mean two 741's, got 6pcs. of it and thought i can use it instead of tl071.
mje340/350
2sc4793/2sa1837
You must use MJE15033/MJE15032 for H900, but with B500 at lower rail voltage there are many TO220 drivers.apex,
mje15033/15032 any replacement?
regards
ok... i found four tl072 in my boxes,ill use it instead thanks a lot apex, been a great help for us who wanted a bit of power, and more power to you
Apex..its my project B500...
Uploaded with ImageShack.us
there no link to a specific pic @ imageshack.
Sorry, this my images:
[IMG=http://img99.imageshack.us/img99/4508/atasx.th.jpg][/IMG]
[IMG=http://img718.imageshack.us/img718/4476/sampingb.th.jpg][/IMG]
[IMG=http://img405.imageshack.us/img405/5536/depanr.th.jpg][/IMG]
very nice amp!!!...those caps are real huge!!!...
What about heating, you use only one fan for cooling?
I used HS with dimention 40cm x 7cm x 16cm. In test to drive speaker R-L 4 unit 15", each side 2 speaker 4 ohm with 50% volume...It's PA hot but I still can touch the HS...not so hot.... If in operasition PA so hot, I will add fan...Thanks Apex... your LOGO I will write in my box PA
@Eesbiboi..
Thanks..I used cap genuin Philips 2 x 17.000uf/65-100VDC .
http://upload.kapanlagi.com/h/20100601075525_elko_4c045a7d995d8.jpg
- 500W PA amplifier with Limiter
