No, not into the same loads - you'll need to increase the rail voltages to increase the power.does that mean, adding more output trannies would increase h900's power output up to such 1200w???... ...
Running lower impedance loads (not recommended) you would have increased power output.
I agree with expirience diyer, I have 2500W amp, but this amp is not for first diy,No, not into the same loads - you'll need to increase the rail voltages to increase the power.
mjl4281a are 350v 230w 15aI will post schematic for PSU and protect soon.
Full power of this amplifier is not 900W. Power with THD 0,5% is 1200W on 4R load, and 1800W on 2R load. Output transistor must be MJL4281A/MJL4302A for maximum power. For step mosfet use IRF2807. MJL21193/MJL21194 can be used for full power on 4R load.
Transformer minimum 1500VA for one channel 4X40V AC + 2X20V for protection circuit. 2X35A bridge and 8X10000uF/63V for PSU... are you still interesting to build this amplifier?
mjl21193 250v 200w 16a
how about mj15003 250w 140v 20a
and mj15024 250v 250w 16a
MJ15024/MJ15025 can be used (crown), MJL21193/MJL21194 also.mjl4281a are 350v 230w 15a
MJ15003/MJ15004 can be used only for B500 (B250) with +/-65VDC rail voltage.
mjl4281a are hard to find locally
but mj15025 are already available maybe i'll go for mj15025 next time
250w 250v
what is psu specs for mj15025
transformer ,caps, diode
No need for MJL4281A, I use it only with higer rail voltage for increase power on 8R load,mjl4281a are hard to find locally
250w 250v
many people making money of assemblying then selling like what you called "monster amp" thats not new here in our place,i'm saying this because i'm one of their victim
they build me monster amp and i pay them,i still remember as they say i will build you a thousand watts amp,he he he.that's the reason why i dig to much of this knowledge and because i'm a victim of people who take advantage to those who knew very little in this field.i'm verry thankful to all the people specially APEX for sharing their knowledge and experience in this field,and support
warm'st regards
warm'st regards
Not this "monsters" I mean schematics on the net, but expirience is not for free,many people making money of assemblying then selling like what you called "monster amp" thats not new here in our place,i'm saying this because i'm one of their victim
warm'st regards
It's clear, I mean "monsters" from your post,for clarification
i did not mean your design,
and experience,i can thank them for they fool me once,but because of them i gained experience building my owned stuff,with the help of the community
regards
hi apexaudio
greetings completed amplifier sucessfully great detailed sound
very powerful amplifier very sweet sound .THANKS for your schematic and
COOPERATION all the way otherwise this great amplifier would not have
been possible no heating problems today i will make dc protector
1 can i put 4 pairs more on same heat sink would it result in more power in 4
ohms do not want to run amp in 2 ohms
2 mj 15024 15025 available but i suspect fake transistors
THANKS once again apex audio one more milestone crossed
DIYERS TRY THIS AMPLIFER
thanking you
andrew lebon
thanking you
andrew lebon
Yes, but not can be on this pcb (larger case).Hi Apex..can I used TR Sanken 2SA1494/SC3858 instead SA1943/SC5200 to high output PA?
Great news,hi apexaudio
thanking you
andrew lebon
Thanks Apex..How much power will carring out with 4 pair SA1494/SC3858? more than 500watt/4ohm?
Pozdrav..
B500 can produce 650W maximum,Thanks Apex..How much power will carring out with 4 pair SA1494/SC3858? more than 500watt/4ohm?
Pozdrav..
Pozdrav..
H900 can have 1200W maximum on 4R load.hi apexaudio
thanking you
andrew lebon
Yes, you can connect primary in parallel, and secundary in series. Conection beatwin secundary will be CT, and you have 2x84vac at the end of secundary.Hvala unapred....
Yes..I mean with B500...
More question: For PSU H900, in my place very hard to find transformator 40vac-40vac-0-40vac-40vac. Can I used 2 trafo CT 42vac? Please help me with diagram.
Regards..
Thanks alot Apex...Yes I undestood..If each trafo 10 Ampere, what 2 trafo will be 20 Ampere or 84vac x 20 A = 1680 watt??
Pozdrav..
- 900W H-class PA Amp with Limiter
