Well, I did a bit of measuring last night and found I made a mistake in my wiring of the heater circuit. I haven't corrected it yet, but hopefully I will get to it tonight. I reversed the pin numbers when I turned the board over and instead of wiring the heater to pin 4+5, I went to 5+6. Doh!! I hope I didn't blow anything up in the process. There was no smoke or unpleasant smells, so I still have hope.
Well, my found mistake did nothing but take me in circles. At the end of my chasing, I am back where I began.
So here are my measurement. I measured from ground to pin on everything with the tubes in place and everything powered up. The neon bulbs lit for a while and then went out while powering up.
6SN7
Grid 2 - 1.2 mV
Plate 2 - 153.5 V
Cathode 2 - 3.83 V
Grid 1 - 1.2 mV
Plate 1 - 150.1 V
Cathode 1 - 3.85 V
ECC88
Anode 2 - 176.4 V
Grid 2 - 152.9 V
Cathode 2 - 153.3 V
Anode 1 - 177.9 V
Grid 1 - 149.5 V
Cathode 1 - 150.4 V
Screen 1.1 mV
6SN7
Grid 2 - 1.2 mV
Plate 2 - 153.5 V
Cathode 2 - 3.83 V
Grid 1 - 1.2 mV
Plate 1 - 150.1 V
Cathode 1 - 3.85 V
ECC88
Anode 2 - 176.4 V
Grid 2 - 152.9 V
Cathode 2 - 153.3 V
Anode 1 - 177.9 V
Grid 1 - 149.5 V
Cathode 1 - 150.4 V
Screen 1.1 mV
I did my prodding and everything appears to be the right value. I ran through all the resistors on the board and found no errors. I also verified the caps. Any other suggestions?
By the way, what sort of voltages should I be expecting to see on the ECC88?
R8 and R9 should divide the voltage down to 110-120V or so at their junction. That's the voltage that should be seen at the ECC88 grid. You should see a few volts higher on the cathode.
If your meter has a low impedance, it can upset some of these readings (e.g., the ECC88 grid voltage)- use one with a 10M input impedance, minimum.
I am using a Fluke digital scope borrowed from work. According to the manual, the input impedance is only 1M ohm. I repeated the measurements with a Craftsman el-cheapo meter with unknown input impedance and got the same readings.
With no tubes in I am getting:
side 1
198-193 V across R8
193-185 V across R10
Side 2
211-205 V across R8
205-198 V across R10
With tubes I get
side 1
150-150 V across R8
150-150 V across R10
Side 2
154-154 V across R8
154-154 V across R10
side 1
198-193 V across R8
Side 2
211-205 V across R8
With tubes I get
side 1
150-150 V across R8
Side 2
154-154 V across R8
Doh!! I read 9 then look at the board and measured 10. A bit of a dyslexic moment.
side 1
198-193 V across R8
.9 mV-185 V across R9
Side 2
214-208 V across R8
.7 mV - 201 V across R9
With tubes I get
side 1
152-151 V across R8
1.2 mV - 151 V across R9
Side 2
154-154 V across R8
1.2 mV - 154 V across R9
side 1
198-193 V across R8
Side 2
214-208 V across R8
With tubes I get
side 1
152-151 V across R8
Side 2
154-154 V across R8
I guess I was asking, what's the load impedance and is it balanced?
In any case, whatever your wiring error is, you've somehow bypassed the R8/R9 divider network- the grid of the ECC88 is nearly the same voltage as the plate of the 6SN7, and clearly that's wrong, since a voltage divider is between them. Is this build point to point or on a circuit board?
OK, try this: with the power off, measure the resistance between the 6SN7 plate and the ECC88 grid.
Any chance you could post a pic? I'll take a look at Jack's board (I have one built up on my lab bench) and see if it's possible for a dyslexic to stick a resistor into the wrong hole.
you're opening yourself to all sorts of scatological humor with that one...
That's why I was giggling when I typed that.
Well, I checked all the parts are in the right holes
and I lifted the non ground leg of R9 and jumpered it to the junction of R8 & 10. I can now map out the schematic correctly. Unfortunately I still have about 150 V at the junction of R8,9,&10 with the same at the grid pin.
Arrgh!![pirate :Pirate: :Pirate:](https://files.diyaudio.com/forums/images/smilies/pirate.gif)
Arrgh!
- ImPasse Preamplifier
