The Advantages of Floor Coupled Up-Firing Speakers
But while you're here: how are you coming along with the elliptical waveguide? One day I'd like to own loudspeakers that allow me to remove absorption from the floor and the ceiling.
Advanced development is completely stalled - I am swamped with work. I had a guy helping but now I don't, so I have no target date. I have changed the cabinet and crossover design on the Abbey.
That's bad news.
Is the data on your website already from the 12a version? By the way, please fully label your diagrams. People might link them from other places and important information will be lost.
No. The looks will change, but not so much the performance, but there are two changes that make a little difference - the crossover and a larger foam plug. I have not posted the results from these yet - again, no time.
I dont follow "please fully label your diagrams"?
Is there any polar data available for that speaker?
I took some off axis curves when I measured, but I do not have a nice turntable. When I get around to measuring them again I might spend more time on the off axis response.
As for the "kidding part", using the same approach characterising the speaker speaker as I did in my long gone pro-audio days I'd call the HF/Upper-MF unit 60 Deg (H) X 20 Deg (V). Directivity is actually quite constant for this planar/horn combo, after equalising the (expected) HF rolloff up to around 15KHz and down to the X-Over frequency.
Due to the relatively large diameter LF unit we have a reasonable seamless link in terms of off-axis response in the horizontal plane, in the vertical plane there is a pretty serious step, but it seems to cause not all that much trouble (contrary to expectations).
Still, things get a little more interesting when two units are stacked tweeter to tweeter with the fairly significant distance of the LF units now producing some substantial reduction of vertical dispersion angle.
Hence my take to use two of my LF units in MTM around a very large magnetostat/horn combo to get a better match of directivity in the vertical plane.
after all it's "25cm W by 49cm H by 31cm" Transmission Line with OptiSlope crossover (60 dB/octave)
It is not a transmission line. Nor does it say it anywhere that it is a transmission line. It says "Transmission Line Port", which is a nickname that got stuch due to the way that port is folded up, similar to a TL.
As for the 60dB/8ve, that is real. And the step response still does not look too shabby. :) I find that the worst crossovers are those with slopes that in-between. Fourth order acoustic seems especially bad from experience. I find no-xover (single way) or 1st order in most cases preferable. Where that does not work too well using very steep slope crossovers works rather well. You may want to try.
Ciao T
That would be very nice. 'Til then I keep on waiting for Earl's elliptical waveguide to happen.
Your call. You may still want to have a look at (and listen to) the larger size and format pro audio magnetostats with waveguides. Quite a few actually have pretty good "Constant directivity" and high sensitivity coupled with decent power handling at prices that make them quite attractive.
And they sound like no compression driver I have heard ever did. It is hard to go back to anything else after you get used to these though.
Ciao T
This one gets along with rather light absorption ...
Several I have been playing with had such data available, nothing I am at liberty to re-publish. I guess you will have to ask the driver manufacturer...
Ciao T
No complete polar response data, but the -6 dB beamwidth of the Beyma AMT looks good:
http://profesional.beyma.com/ingles/pdf/TPL150H.pdf
Maybe Dieter Achenbach can give you the plots of the Limmer horn for the Stage Accompany.
I'm more interested how the whole speaker performs and not just one component.
Any polar data available?
Unfortunately not, but i have a measurement which was made
with microphone on the bottom and in 150cm distance.
Since acoustic center is on ~130cm height for high freqencies,
this would correspond to about 40 degrees off axis vertically.
That speaker is not in the focus right now, but when i have got
some time i will do more measurements, serving for
comparation with my DMLs.
"Dipol 08" 40° off axis vertically, frequency response and step response:
