Experience with this DIY DAC ?
The secondary RC filter pretty much works independently from the rest of the circuitry.
I know the F5 has a huge bandwidth. If you are already using a 1K/.0022 filter it would be better to limit the bandwidth at the F5s input circuitry. That has been discussed by Mr Pass, I believe even in his original article. 10pf across the inputs comes to mind, but I could be off.
I thought someone might be able to help me diagnose this issue. :eek:
I recently noticed a big difference between playback levels between my Mac Mini (which is outputting to the DAC via USB) and my Oppo 980 player. A few weeks ago I pushed my receiver to clipping (for just a moment) while using the Mini/DAC setup. Ever since, it seems that I have to "crank" the receiver to produce a normal loudness level. As a reference, -20 dB is pretty loud when using the Oppo. The Mini/DAC might need to go to -0 dB for a comparable level.
There's no distortion, buzzing, humming, or odd artifacts during playback either way. The speakers seem fine. The receiver is fine. It's just odd.
I feel like a real Homer (Simpson). When I pushed the receiver to distortion levels, it seems that iTunes adjusted down its level to compensate. I've changed the sound level back to 100%, and the receiver/DAC combination is once again way loud at -30 dB.
Thanks for pointing me in the right direction.
I tried to experiment with 24bit 192khz to see how or if it sounds good at all.. but all I got was hiss...actually I could hear the begining of the song by right away it went to hiss..
I uses XXHighEnd to upsample.. I checked the documentation that came with it
and I set the switches right... has anybody tried 24/192 successfully?
